We had some rain, and sometimes that knocks our signal out...our other two televisions came back on fine, but the third did not. It says "searching for signal" 771, etc. While only receiving a couple of channels. I rebooted several times, even disconnected the satellite in and did a complete reboot. Still nothing. When speaking with a technician on the line, they said there could be water in the line. This I doubt only because we recently had a tropical storm with 10 times more rain than this last event, and everything was fine. Any other suggestions short of calling a technician out?
    Master:
  • 469 Answers
If the connection is bad, perhaps you got water into the wall or wherever and it got into that cable only. This would have little effect on the other cables because they are isolated by signal splitters. Tips To Be Secure Whilst Driving At Evening AmanStino
Posted on Dec 27, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • Multi-color,silver,golden,rose gold decide your choice which you like.
  • High-speed,transmission rate synchronization and transfer music, contacts, quickly and efficiently.
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
  • Perfect for your some Apple device , high speed data transfer will make you have a good time
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters USB Charger Cable for Apple...
    President:
  • 1,140 Answers
I have to agree with the engineer. From the symptoms you describe, the first thing I would do, is check for water in the cable.
If the cable connection isn't waterproofed at the dish or at any other joins in the cable, water can (and does) get into the cable.
If water gets into the cable, gravity will pull it downwards. The water has nowhere to exit the cable until it reaches the television. Water in the cable will also interfere with the impedance of the cable and cause signal loss.
It's not really about whether it's raining at the time the signal is lost. It's about the amount of time it takes the water in the cable to seep through it.
I suggest you check all external connections on the cable and consider replacing the cable before calling an engineer. If you do replace the cable, be sure to spend the time waterproofing connections to avoid the problem recurring. Replacing a 10 meter length of cable should cost no more than £7 / $10 including new connectors if you do it yourself. Don't buy "low-loss" Co-axial cable though - it's rubbish - buy "Copper Foil Satellite Cable". It's worth extra few cents per metre!
Please rate this solution if you find this helpful. Thanks.
Posted on Oct 16, 2010
  • DILLIGAF
    DILLIGAF Oct 16, 2010
    As you have several televisions, you will have several places where cables are joined/split. However as all televisons have been affected, the source of the problem will most likely be a section of the cable that supplies all 3 - most likely place is the dish.
  • Paul Bade Oct 17, 2010
    Intense rain can obscure a satellite signal while it is falling, especially if water is running heavily on the surface of the dish (alters the signal focus on the LNA pickup). I assumed that is what the writer meant by the signal occasionally being knocked out.
    If there is water inside a coax cable all the way to the receiver end, I would expect some visible sign (corrosion or dampness) when it is removed from the receiver. That would be a quick answer to the question, for as BElectric says, the impedance of the cable is changed, and if corrosion starts inside the cable, the impedance changes even more.
    This cable is probably not directly connected to the satellite antenna, since it is one of several sets in the system. It may in fact be entirely indoors, perhaps connected to a splitter connected to the output of an amplifier or satellite receiver unit, but a building structure problem (flooding or poor runoff drainage, termites, etc.) could be letting water in, either at a connection or someplace where the jacket was damaged.
  • 1,606 Answers
Move the problem set to one of the other rooms with a known good connection and test it using that connection (or if that is not practical, bring a known good set into the room with the problem TV and use it to verify the connection is good).
If it is the TV, it is possible its tuner was damaged by lightning. I have seen a set with one part right at the input and another in the power supply blown out, but no damage to anything else in the set or in the building (although it is very uncommon to get off so easily with lightning strikes).
  • DILLIGAF
    I wouldn't advise moving a working TV and connecting it to a cable which may be waterlogged. Moving the TV that wont retune to a known working connection should be fine though.
OVHD when there is rain OVHD does not work
Your television signal becomes weak in the rain because it is satellite based. Even if you don't have a satellite dish, the company that supplies you does. You need to contact them direct. Or, if you do have a satellite dish, you need to upgrade to either a larger one, or if you are on analogue, you need to upgrade to digital.
Apr 28, 2018 | Cars & Trucks
Has snow. We just got it from a friend a week ago. Picture was fine for a few days then snow. Thanks!
Satellite or cable? Snow is indicative of a satellite dish that has moved, or something is in the way of the signal, tree branches, leaves, rain, sleet and snow.
If not, check all the cables at the back.
Nov 22, 2015 | Mitsubishi WS-65413 65" Rear Projection...
Why do I lose All BBC channels every time it rains It is an LG tv with built in freeview
Are you using a Satellite dish for your signal? Rain adversly affects signal with satellite dishes, or if the incoming signal is from a satellite based transmission from the BBC, channels will be "knocked out" temporarily.
Aug 10, 2014 | Televison & Video
No signal and sometimes picture freezes
sometimes you can have weaker signal, and pictures freeze...
it can be caused by bad weather, by thunderstorms, heavy rain....
you can't do anything about it, just get stronger antena....it can improve your gain from signal, but never for 100%
Jan 13, 2014 | Polaroid Televison & Video
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
Rain sensing wipers on 2005 320i BMW do not work correctly
but windex on the wind-sheild and rain-x especially where the rear-view mirror sits. dust can give a false signal to the wipers.
Oct 29, 2009 | 2008 BMW 3 Series
Mono/stereo flashes in upper left tv
The mono/stereo is an indicator of the audio signal that the TV is outputing. Like most car radios, they have an indicator that tells you when a station in coming in clear, which may be just an LED or a light. When the signal is weak or when your on a non-stereo station the indicator will not be on. What signal are you providing to the TV? Cable, OTA, STB output??? low RF signal level could be the cause for this.
Mar 18, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
