Question about Samsung SRP 350 Thermal Printer
Thermal printer settings
Wht is the dip switch settings
    Problem Solver:
Can someone help me I loaded the srp-350pluscopg driver but the printer will not print anything even when i send a print test page the page is blank.
Posted on Nov 03, 2009
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please reference the user’s manual on page 11 and 12 for dip switch settings.
Posted on Apr 16, 2009
I replaced a tsp600 with a new tsp600
There are DIP switch settings in the printer, Check the old one and change the new on to match.
Feb 22, 2014 | Star Micronics TSP600 Thermal Printer
I need to set tear off option in my sato cl 408 barcode printer please help me
Set dip switch 3-1 off and 3-2 on. Recycle power.(Operating mode tear off)
Sep 07, 2011 | SATO CL408e Thermal Printer
My zebra 105 se wont print using RS232 serial cable
Make sure the serial dip switch settings match your com port on the computer. You need a null modem cable or adapter.
Mar 04, 2011 | Zebra 105Se Thermal Printer
I cannot seem to cancel an old job stuck in there. I have hit cancel, powered off and on, unplugged. Everytime I try to print a new job it puts out this old one.
moz-screenshot.pngThe best thing to do is do a memory reset. But this could also clear pages and formats, user defined characters and fonts, configurations,tables,or all of these parameters.
To reset memory
1.Turn off the printer.
2. Set the DIP switches to reset a portion.
3. Press and hold the Feed/Pause button while turning on the printer. The printer prints out a hardware configuration test label.
4. Hold the Feed/Pause button for 1 second. The printer resets a portion or all of its memory.
5. To exit test and Service mode, turn off the printer.
6. Reset the DIP switches to their original setting and then turn on the printer.
That should do the trick.
Sep 13, 2010 | Intermec EasyCoder 4420 Thermal Label...
Im using a Star TSP600 printer, it respond to the computer but the paper prints a lot of quetion marks insted of the normal text, what mite be the problem
Make sure the dip switch settings are correct. This is probably a serial interfaced printer and the baud rate or parity is wrong. Do a self test on the printer by holding down the feed button and turning on the printer, release button after the printer starts printing the test page. Now make sure your computer settings match the printer settings exactly.
Apr 10, 2010 | Star Micronics TSP600 Thermal Printer
What should the dip switches be set on for this to
It does not matter. What is important is the the settings are the same as your computer and the program printing to it. FYI: The last switch is the "STOP BIT" switch.
Look in the printing program and in the PC's control panel, in the "HARDWARE DEVICES" and choose the serial device. If they are set the same, make sure the PC's BIOS has the serial devices turned on.
TRIVIA: Most printers and computers are set to N-8-1
Good Luck
Dec 15, 2009 | Epson TM T88 Thermal Printer
Epson THermal Printer TMT88 only prints question marks?
There are DIP switches on the back of the printer, set them the same as the ones on the printer that works. This should solve your problem.
Apr 16, 2009 | Epson TM T88 Thermal Printer
I cant get the printer to not loose its initialization.
There is a battery i that holds the configuration and it is mounted on the board since it holds the fomat I think the battery is ok
since it holds the format ok you are getting something ( a space or character) in the data stream going to the printer
if you put the printer in manual mode dip switch settings 1 on to and 1 on botom you can do a test print and make sure you have label calibrated sometimes if dat will not it on label the printer wi not print
good luck
Oct 31, 2008 | Intermec EasyCoder 3400 Thermal Label...
How to make Epson thermal printer print darker?
Change the dip switches settings to
PLS DONT FORGET TO RATE AS FIXYA, THANKS!!
Apr 25, 2008 | Epson TM-T88III Thermal Printer
Samsung SRP 350 Thermal Printer Logo
691 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
