Question about LG LSC26905TT Side by Side Refrigerator
I have a lg side by side with a fault code of dh er and the evap. is frosted up. I would be happy to get any information on the problem.
  • LG Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Error message on the display panel that says ER dH - inside of refrigerator getting warm - water dispenser, ice, temperature control on front panel not working
ER dh means you have defrost issue that needs to be addressed asap. The evaporator has frosted up so badly that the circulating cold air cannot get to the refrigerator. You would need to get inside the freezer back panel and remove it to access into the evaporator coil area. Test the defrost circuits to see if the defrost terminator is broken. If it is, replace it and melt the ice build up as well.
Good luck
Jul 16, 2011 | LG Refrigerators
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
Control panel shows "Er dH"
The “er dh” code means a problem with the defrost cycle. It is triggered when the defrost sensor does not reach 46 degrees F within 2 hours of the defrost cycle starting. If indeed the defroster is not working, the evaporator (in the bottom of the fridge in the freezer compartment and behind a plastic cover) will eventually ice up completely, blocking the flow of cold air to the upper compartment. Use a thermometer to check the upper compartment to verify that no or little cool air is reaching it.  If the evaporator is iced up, the defrost cycle is not working. Quick fix to restore operation to the upper compartment: tape over all vent holes in the upper section to keep that cool while you work below. There are about 6-7 vent opens in the back wall and two large one on the floor of upper compartment. Remove freezer door, drawers, slide rails and pull back the plastic cover (2 screws hold it in place, one in the center and one behind the ice maker) at the rear of the freezer section to expose the evaporator. Spray hot water on the ice accumulation on the evaporator (it looks like a radiator) to melt it (remembering to sop up what flows to the drain pan at the rear). The entire operation can be done in about 30 minutes (most time is used for removing ice and sopping up water from the drain pan). All should be ok for 3-4 days depending on humidity before the evaporator ices up again.  In the meantime, order a replacement control board. You can view this by removing a panel w/ 3 screws at the rear left of the refrigerator. This panel controls all refrigerator functions, including defrost. Most likely, the integrated relay for the defrost cycle failed. Swapping out panels is a 10 minute job. Panels cost about $116 incl shipping from repairclinc.com. Shipping is about a week.  You can find a free service manual on line that will help to identify all parts and is particularly useful for removing doors and trays so you can get at the evaporator.  All in all, the customer service is useless. The fridge however is very easy to work on and amazingly simple. The replacement board has a slightly different relay for the defrost heater, so LG may have realized a problem existed with the original. It is also possible that electrical surges damaged the relay.  In any case, 10 minutes and $116 seems pretty minor to have the fridge back to new condition. Good luck.
Jan 22, 2009 | LG LFX25960ST Stainless Steel French Door...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
135 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
