Question about Fujitsu AMILO D-8820 Notebook
What do the messages on the screen at bootup say?
  • 942 Answers
The messages will say
Intel Core 2 Duo
Realtek Gigabit Adapter 2.4 GHz
these messages will appear in a black screen at the point where you turn on the pc. After a few minutes, it will boot to windows..
Posted on Oct 16, 2010
My nextbook tablet has a blue screen
This is the BSOD, or 'Blue-Screen-Of-*****'..
Indicates a serious problem preventing bootup.
As it has no message shown, your only option is to take it in for a checkup.
Nov 20, 2017 | Nextbook Tablets & eReaders
Tip
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
SOLUTION (FROM HP):
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
on May 21, 2010 | Computers & Internet
Intel pentium - booting up ok, but nothing shows on screen. Pressed F12 came up with error message error setting up the MD3 over power button. Also, unable to locate media direct BIOS table.
If your computer is showing nothing on screen it is not booting up OK. Are there any beep codes being given during bootup? One single beep at the end of the POST sequence is OK, anything more means some kind of hardware error found during bootup. Media Direct 3 is a Dell product that has caused a number of problems on its computers. See Dell MediaDirect . Your option may be limited to contacting Dell support.
Jan 29, 2017 | Intel Computers & Internet
Disk error msg on bootup
Remove all the external peripharials from the system and restart it......it will work!
Jul 29, 2010 | ASUS Eee PC 1000H Laptop
My Garmin Nuvi 760, after the Garmin bootup screen, goes to a press dot screen and then freezes. I have tried setting back to factory setting but that did not work. Any Suggestions?
try a master reset:
How to do a master reset:
1. Turn on the unit
2. While it's booting up keep pressing the bottom right corner of the screen.
3. A message will appear asking if you want to clear user data. Answer yes.
4. Bootup will continue. It's after this that you have to re-enter or confirm your country and time zone.
I hope this helps
Oct 29, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
My hp gives me a no bootmrg message
please clarify that what message u ate getting exactly e.g. disk boot failure or simply blank screen
Mar 05, 2009 | HP Pavilion DV5234US Notebook Laptop
On bootup checks, stops at 02FC Main and second fans failed. Black screen with bootup messages. ?Has the MA7 even got two fans? How to correct.
Sounds like you may have a virus or trojan of some sort. They are hard to get rid of but try downloading avg 8.0 it's free and picks up most trojans and viruses. If you get a black screen with boot message just hit control alt delete together and your pc should bypass this problem and allow you in. If avg doesn't pick up trojan or virus it maybe a software failure but it will usually tell you whats missing and if pc was working fine and just started this it is most likely a virus or trojan
Jul 26, 2008 | Gateway Computers & Internet
Bootup
Have you tried changing the cmos battery on the motherboard?
Jan 07, 2008 | Computers & Internet
Computer won't bootup
help have a dell latitude c800 must have a a email viruse cause it has blue screen with message "beginning dump on physical memory" then it has black screen with message disk error no drive found. did not get a cd for rebooting dont know what to do. it is refurbished and running windows 2000. would appreciate any and all help.
Nov 11, 2007 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Fujitsu AMILO D-8820 Notebook Logo
242 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
