Question about Makita Keyless Drill Chuck Set, HP1501 Model 192692 - 0
Chuck won't turn, motor running but chuck will not engage. I have the 14.4 volts with 1/2 inch chuck.
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: How do I remove the
look under the tip section, I posted detailed instructions that will work with this drill also.
Posted on Dec 27, 2010
The chuck wont tighten
Sometimes the chucks jam when opened all the way. A firm hand and a quick **** of the chuck sleve will release it sometimes.
Nov 08, 2012 | Ridgid Factory-Reconditioned ZRR9001 18...
Chuck will not turn
Make sure the torque selector which is the black ring with numbers and a drill symbol on it behind the chuck is rotated to the drill image for drilling and general purpose use.
Feb 11, 2012 | Dewalt 18 Volt Compact Drill Kit
How do i fasten the the drilling bit in the machine ?
For the pictured drill motor, you put the bit in and use a "chuck key" to tighten the chuck onto the bit...
If the photo is not your machine but you have an SDS type chuck, you insert the bit, pull back on a collar and twist the bit until you feel it engage and release the collar. When seated properly you cannot pull the bit out without pulling back on the collar.
Dec 10, 2010 | Makita & 1/2 Inch Drill
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
Chuck not engaging
The speed selector is between two speeds or the output shaft from the motor to the chuck is broken/stripped. If your drill has a clutch setting you may check to make sure it is on the lowest number possible.
Nov 22, 2009 | Drills
Our Powermatic PM66 will not start... the motor will run if the contacts are manually engaged but the contacts will not pull in using the start switch
If the motor runs without the switch then the problem is the switch. Pull out and blow it clean of sawdust and try again. Also check the connections at the switch to make sure they are tight.Hook a meter up and turn the switch on to check for continuity. Remember, switches wear out also and need to be replaced.
Oct 14, 2009 | Powermatic 1660802K Model 66 Special...
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Makita Keyless Drill Chuck Set, HP1501 Model 192692 - 0 Logo
195 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
