Cogged wheel on show - Computers & Internet
  • 712 Answers
Please explain your problem more clearly.
Posted on Oct 16, 2010
Nishiki bravo bicycle will not engage gears when pedalling
has the cog seperated or snapped off the wheel as in can you freeturn the wheel and make the cog go around or does the wheel spin but the cog doesnt move,
if so your up for a new rear wheel/cog
Jan 28, 2013 | Cycling
I have a 2004 GSF600S, when I put it on centerstand and spin the back wheel slowly. There is some regular clicking sound from the transmission / gear box section. You can actually feel the click vibration...
check the tooth profile on the drive cog and the cog on the wheel
if they are more spiky that properly formed as in a new cog
then what is happening is that the pitch of the cog has altered from wear and the pitch of the chain ( distance between link pin centers ) is no longer compatible so the chain tends to ride up on the teeth and then clicks back in place
the fix is a new chain and cogs or if the teeth are good , just a new chain
Oct 14, 2017 | 2004 Suzuki GSF 600 S Bandit
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
How do I remove the gear cog from the rear wheel of a mountain bike? I have tried with a freewheel tool, but it wont budge.
Take it to a shop and let them do it, you probably will only pay a minimum charge. We use a bench vise to hold the tool and then put the wheel with the cog on it, then turn the wheel.
Apr 17, 2011 | Cycling
My bicycles chain fell down,and I cant put in on again, Do you know some repairer who can repair it,around the Leytonstone or maybe near it? Many Thanks.
There's a trick to putting a chain back on a bike. First fit it onto the back wheel. Then hold it on the top of the front cog wheel (at the pedals) Get someone to lift the back of the bike so the wheel is off the ground. While the wheel is off the ground and you're holding the chain on the top of the front cog wheel turn the pedals forward, with your other hand, as when you're cycling and as it turns the chain will go on.
If you don't have someone to hold the back wheel up off the ground you could hold the chain on the bottom of the front cog wheel and turn the pedal backwards. The chain will still go on.
Nov 13, 2010 | Cycling
Dura ace sti hangs on middle cogs on cassette.
change the cable ,because the have damage in the middle,
Oct 20, 2009 | Shimano Cycling
Car starts but sometimes makes a whirling noise. I was told it was the starter
sounds like the starter is not disengaging the fly wheel quickly like it should when you turn the key the starter cog connects upto a fly wheel that has teeth all around it when the teeth of starter cog connect between teen on wheel it spins it to crank your car then goes back to starter if you hold your key on after starting the noise you hear is the starter cog(teeth ) still engaged in wheel if this is the sound it needs to be serviced not neccassarily replaced
Jun 06, 2009 | 2003 Chevrolet Impala
Computers & Internet Logo
David Payne
David Payne
