Question about Kitchen Ranges
I have a whirlpool washer(commercial capacity 7 cycles) (extra large capacity) and when i put the water level on anything but the small the water keeps running for hours.. BUT if i keep it on Small level it runs like a charm.. what could be wrong?
  • cinngeo Oct 16, 2010
    is this something i can change myself? or do i have to have it repaired?
  • 712 Answers
The water sensor must have gone faulty. It may identify only the smallest level and the maximum. A replacement would be a fix.
Posted on Oct 16, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    If you are technically confident you can do it all by yourself. But if the washer is new and if you are not that confident go for a local repairman.
Whirlpool heavy duty commercial washer, mod# CAM2742TQ0. Washer does not fill all the way on rinse cycle set on large load.
The service manual shows this machine as a timed water fill. When the washer is filling in rinse, is the flow strong? If not, check the screen on the water valve at the hose connection. If clogged, you can try and clean it with an old tooth brush and a spray water bottle. If not clogged, there are two water level switches. You could have an issue with the high level switch.
Jun 24, 2016 | Whirlpool Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
My extra large capacity Whirlpool dryer does not dry in one cycle. Even if I only put a small load it takes at least 3 cycles to dry
There maybe an air flow issue. With the dryer on check the air flow from the exterior location of your home. There should be a good flow of warm/hot air coming out. If not the inside of the dryer may be full of lint.
Feb 21, 2011 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
What is the capicity of a GE WWA7600S washer
Here is the user's manual:
http://genet.geappliances.com/DocSearch/pdf/49-9810.PDF
They never talk about weight or capacity other than
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
Oct 17, 2010 | GE Washing Machines
The machine fills up with water but does not shutoff.
The water level is controlled by a pressure switch that is located behind the load level selector knob in the operator console. The pressure switch has electrical connections and an air hose that runs to the bottom of the wash tub. In many cases the air hose comes loose from the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
Read through the link and let me know if you have any questions. If this isn't a simple matter of a loose air hose, verify your electrical contacts are clean. If all these preliminary checks fail, replace your pressure switch. I hope this helps you.
Jun 29, 2009 | Whirlpool ET8CHEXSQ Dryer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
