Question about LG Televison & Video
Connecting DVD to TV, both LG. Ie which ports go where!
  • 1,183 Answers
Well the DVD player would have come with the connecting cables. Either and S-vedio (black round connecting jack) or A/V cable (One red and One yellow) The TV would have the either an S-video port( Icon showing TV) or the Two round Input connector again color coded , match the cables with the conectors.
Change the Vedio from TV mode to AUX using your remote.
For detailed help you can refer to the product manual on the following site.
http://au.lge.com/support/manual.jsp
Make the selection carefully in the drop down list for the model that you have for both the TV and the DVD .
In case you need more help , send me the model number for both the TV and DVD , i would be more than happy to assist you
Thanks
Mandeep
Posted on Jun 03, 2008
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jun 03, 2008
    Here's How:
    1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
    2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
    3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
    4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
    5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
    6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
    7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
    8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
    9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
    10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
    11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
    Tips:
    1. If Cable TV is coming in directly from the wall with no Cable Box, the only option is to connect the Coaxial cable to the RF input on the DVD Recorder and then output to the TV using either RF, composite, S-Video or Component audio and video cables.
    2. Some DVD Recorders require you to make an RF connection as well as an A/V connection in order to use the Electronic Programming Guide (for example, Panasonic DVD Recorders that include the TV Guide On Screen EPG). Always check the owner's manual before making connections.
    3. Feel free to use connection combinations when hooking up your DVD Recorder. For example, you can connect from the TV source to the DVD Recorder using a coaxial (RF) connection and then output using S-Video and RCA Audio to the TV.
    4. Make sure if you are using A/V cables to connect the DVD Recorder to a TV, that you change to the appropriate input on the TV.
    5. Use the best cables you can for connections. Video cables from lowest to highest quality are, RF, composite, S-Video, Component. Which cables you use will be determined by the types of outputs and inputs on the DVD Recorder and the TV.
    What You Need:
    • DVD Recorder
    • Television
    • Television Source - either Cable, Satellite or Antenna
    • Audio and Video Cables
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Jan 06, 2016 | Philips Televison & Video
How to fit anb3530a lg soundbar to toshiba tv
trade your TV or Sound bar to something that is compatible. IE Make it work, No optical port find a sound bar that works with RCA, Make certin you have RCA audio outputs on your tv, if you want the sound bar than New TV
Jul 28, 2014 | Toshiba Televison & Video
What should my input screen on my lg tv be set on?
It should be set to where you have the input(ie...cable box, satelite, DVD etc) connected on the back or side of the TV
Jul 23, 2014 | LG 42LG50 42 in. LCD HDTV
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
Can an lg soundbar be connected to another brand of tv, ie a hitachi? cant gt any sound to come through !!
Depends on whether your tv supports "ARC" ( Audio REturn CHannel) or has an optical out port..the sound bars are designed to work with either the "ARC" function or optical out option
Dec 23, 2012 | LG NB2420A 160W Sound Bar
No signal when trying to watch a DvD. Can watch TV but not DVDs
Hi
Check the input selection on your TV and set it to AV.This option is on your TV's remote control.
Also check the cable connections to and from the DVD.Make sure the colors match on the connecting ports.
Feb 26, 2012 | LG Televison & Video
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
We have a lg, lcd tv.model#37-LD450, we cannot get our DVD player connected so that it plays, any help would be appreciated, owners manual on a dvd and no use
Your dvd will have a scart socket or a hdmi or other socket, ( check manual), connect lead from dvd to tv, output from dvd to input on tv, from one of these ,on your tv remote select the button that changes the av select , that means the button that tells tv that you want to watch signal from dvd ,( or other input devices) ie sky video camera etc it may be av1 av2 av3, you should get a picture on one of these,
hope this helps
pete
Nov 15, 2010 | Televison & Video
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
194 people viewed this question
Computer Repairing
Computer Repairing
