Hi, i need help i cant find my ip adress and i need a wep key to play online on video games
    Problem Solver:
  • 16 Answers
IP Addresses are usually assigned. You shouldn't need to find your gaming hardware's IP Address to do any gaming whatsoever. This is a simple problem that can become very complicated without the proper permissions.
The WEP key is exactly the same as the one you put into your computer in order to use the internet. Without this key you'll have to reconfigure your modem/router...which is a process many people DON'T want to repeat. The most important thing to do when configuring keys and pass codes is to write them down and/or print them out and store them in a safe location.
I can't give you details on how to attain or recreate this key because I don't have enough information regarding your hardware, gaming system, or internet service. What you must do in order to engineer a fix for this is use your best friends...Google and your modem/router's instruction manual(s).
In the instruction manual(s) you'll be able to find the address to your equipment and instructions for proper reconfiguring. With Google you can find the information if you've thrown your packaging away (VERY bad idea!!!). You should be able to do this by searching "how to reconfigure [your modem model here]." Follow all instructions, WRITE DOWN YOUR KEY, then enter your gaming system's Network Connection/Setup options.
For example:
I have a PS3. I would enter Settings > Network Connections. From this point I would select either a wired or wireless connection, choose the easy setup option so it will auto-detect everything, match the security types, then enter the key I wrote down earlier. From your computer you had to create the key yourself when you reconfigured your modem/router.
I hope this is useful and not to confusing. If you didn't set up the connection you'll need to speak with the person who did for the key to your internet.
Posted on Oct 16, 2010
    Problem Solver:
  • 8 Answers
In order to fix this I need some more info. What type of Router do you have? Is it your network or does it belong to someone else.
A little background. WEP is a method to secure computer networks. It requires a password (so to speak) to connect to a router. When the router was installed a Key was chosen and entered on the router and then the computers connecting to it wirelessly.
If you own the network and know the key it is easy. Just enter the Key in your network configuration on your PS3 or Xbox . If not you need to do more steps and while not difficult need to be thought through.
All Routers have a reset switch that restores it to its factory default (without a WEP) but this will prevent all your other devices (including the computer you are using) from connecting to the router if they were configured for WEP.
If you are going to continue I can give detailed instructions if you can tell me the router model
J
Ip adress timed ou
Try power-cycling the router (unplug and plug back in). Make sure wifi is enabled on psp (green light @ bottom left, toggle switch is on bottom left of psp). Also, when typing in encryption key, make sure the encryption protocol settings on the psp are the same as what your psp is broadcasting. So if your router is broadcasting WPA/WPA2 encryption, make sure psp is set to that.
Hope this helps.
Oct 25, 2011 | Sony PSP 3000 (0 MB) Black Console
What is an ipaddress
hi an ip adress is the numeric adress that your Internet Service Provider gives you that your modem holds in memory. to find yours go to google and type in "MY IP ADRESS"
Feb 11, 2011 | Nintendo DSi XL Burgundy
Im trying to get online for my xbox 360 ive just bought a wireless adapter but it says i need a wep key wat should i do
you have to get the WEP key off the router on your home network. sometimes the key will be on the wireless router but not usually. you would have to log into the router using your ip adress 192.168.1.1 is usually the default. you need to log into the router and go to security settings to see the WEP key
Jul 06, 2010 | Microsoft Xbox 360 Console
I cant play my ps3 online
HI,
NOW YOU SHOULD HAVE IT FIXED!!!
I know THE SOLUTION FOR THIS PROBLEM (when you use LINKSYS WRT54G) don't know of this works out for other too but give it a try !!
I've spend hours on this looking.. but I'll spare you my life story..
The first thing you do is look up the MAC-adress of your ps3 which can be found in your network configurations pannel.
once you found this you note this somewhere on a sheet of paper.
Next you go to your linksys router (on your pc)
You can acces this by typing 192.168.1.1 in your browser.
when you are there search were you can fill in a MAC-adress and replace the one you've got by the one of your ps3 (on sheet of paper)
OK so far so good. Then you will have a NAT-type 2 instead of 3 (which means that you don't have to fill in your configurations like DNS and Ip-adress manually) So this you don't get a DNS error.
Then go to network configurations on your ps3 and use simple or advanced (I don't think this makes a difference =) )
But I took simple. Next set everything on automatic. IT IS ALSO IMPORTANT THAT YOU USE THE RIGHT WEP-key (which can also be found in your router configurations)
=> (192.168.1.1 in browser and settings) or ask me if you don't find this
And don't use proxy server or UpNp (the last one makes no difference with me)
ENJOY THE ONLINE PARADISE GAMING AND DOWNLOADING OF PS3!!
If problem still persists, let me know!!
Hope i helped you.
Thanks for using ' Fixya ' and h!!ave a nice day!!
Jul 14, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
I cant play games online
You do not need a DMZ for ps3. jsut setup a SSID if wireless. Encrypt it (for your own saftly) and PS3 has wireless capablity. Just join the network with the SSID and WEP key and the PS3 will get an IP address. Also no port mapping is needed. Leave all port to auto open due to DHCP is going to get your PS3 a new ip every time you turn it on.
Jan 15, 2009 | Sony Playstation 3 (PS3) Console
Cant connect to internet
put this # at DNS entry 4.2.2.2 and 4.2.2.1
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Cant get online ip adress
my problem is that i cant get an ip adrees through my comcast internet .
Apr 19, 2008 | Video Game Consoles & Games
Ps3
If it's unable to find your router, then try moving it closer. 9x out of 10 this is the cause.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
