Question about Keurig B50 Coffee Maker
What does de scale mean? I have cleaned the big water holder & use the reusable filter?
    Problem Solver:
  • 5 Answers
RUN WHITE VINAGER THRU A CYCLE
Posted on Oct 16, 2010
My cuisinart kcup coffee maker is filling the cup slow and not completely full. I cleaned with white vinegar several weeks ago . Do you have a suggestion
Doesn't brew a full cup.
Every once in a while an air bubble may get trapped in the water path. Lift off the reservoir, then put it back into place.
Turn off and unplug the brewer for 30 seconds or more. When you plug the brewer back in, be sure to turn the power back on.
The exit needle may be clogged (refer to "Cleaning & Maintenance" page 18).
Clean the K-CupĀ® holder brewing chamber (refer to "Cleaning & Maintenance"
page 18).
Make sure the water reservoir is properly in place, and perform a Rinse cycle.
De-scale the Brewer (refer to page 20).
If you have repeated the de-scale procedure two times and it is still only brewing a
partial cup, contact Customer Service at 1-800-726-0190.
Cuisinart SS 700 Instruction Booklet
Good luck.
Semper Fi,
Z
Feb 14, 2018 | Cuisinart Coffee Makers & Espresso...
Tip
De-Scale Keurig coffee units
<br /><br />The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.<br /><br />Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.<br />Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.<br />If you taste vinegar..use more clean water, until the taste is ok.<br /><br /><br />
on Dec 22, 2010 | Coffee Makers & Espresso Machines
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
How do you change the water filter?
Sorry to read about your issue.
Their is no water filter to change, you should try the below to clean the unit
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Keurig Special Edition B60 Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
also clean the holes at the bottom of the k cup holder
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
Does not brew, comes out in a spray pattern
also clean out you kcup holder at the bottom holes
Dec 23, 2010 | Keurig B60 Coffee Maker
My Keurig B60 SE has recently started brewing k-cups very, very weak. I have a filter that I can put coffee in and that works fine, and I've even found that when I put the coffee from a kcup into the...
Sorry to read about your issue. plus you may have a bad k kups
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
I'm only getting 1/2 cup of coffee each time I brew. I've changed the filter. What should be my next step?
Their is no filter on the b40 so i dont know what you mean about that.
you model may have one or two brew size 10oz and 8 oz take a kitchen measure cup and check it
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
The water or coffee does not come out correctly anymore. When making a cup of coffee (w/ pod) or just hot water (no pod), the hot liquid does not come out in a steady stream, it goes everywhere. When i...
211333Sorry to read about your issue.
I need cleaning instructions
I used an air-compressor with a small soft rubber nozzle, and blew out the rubber over-fill port, the peircing needle and the reserviour inlet, and it started working like new. I have done this to two seperate machines - that were both having short-pour options, and it worked like a champ
Nov 07, 2009 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
56 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
