Question about Zanussi Dishwashers
Top spinner of dishwasher wont go round - Zanussi Dishwashers
  • Zanussi Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 16, 2010
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 | Dishwashers
Recently my dishwasher KUDSO1FLSS2 is not cleaning the top rack very well requiring multiple washings. Both the top spinner and mid rack spinner (under top rack) turn freely by hand but limited water...
If there afilter on the inlet hose it might need clening,if you have a partial blockage it will reduce the volume of water entering your appliance.Hope this helps.
May 14, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Need to install a new top spinner on the roof of our dishwasher
the medium sized plastic piece slides into the spinner and you put it upto the manifold. you have to remove the manifold so that you can push the smaller piece of plastic through the top of the manifold into the medium sized piece which would be holding the spinner up.
Dec 18, 2008 | Dishwashers
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
123 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
