Question about Fisher and Paykel Dryers
Dryer rattle Hi was wondering if someone can help me, my dryer is making a rattling noise. I have taken the back off and if enough tension is put on the belt its possible to make the noise go away. It sounds like its coming from inside the drum but I'm reluctant to start taking it to bits without some idea of what I might find inside.. If anyone can help it would be much appreciated. Thanks Callum
  • 1 more comment
  • Callumb Jun 03, 2008
    Fischer Paykel Dryer ED56 Autosensing dryer
  • Callumb Jun 04, 2008
    Ok will have a closer look tonight, I think the belt may need replaceing but I don't think thats the cause of the noise - buy tightening the belt I suspect its putting pressure on the bearing - belt is probably a nice cheap place to start. Is it difficult to get to the bearing? As it turns out I only have 3 feet for the dryer but made a wooden foot - it doesn't rock at all but are you saying it must be perfect? that might have caused the bearing problem? (presuming there is one) thanks
  • Callumb Jun 09, 2008
    Thanks for the warning. I have ordered a new belt and bearings which should arrive in the next couple of days. Is there anything in particular I should be aware of when dismantling it? (I'm faily handy at dismantling things)
  • 1,183 Answers
I guess you have stumbled upon the resolution yourself.
The Tub ratlling could be because of three things.
1. The Belt itself , as it might have slacked after use. and needs replacement
2. The tumbler bearing, that would require you to open the tub
3. The holding bolts that connect both the inside and outside tubs of the dryer.
and do check the floor balance of the dryer.if the surface is not even the dryer can tumble and make noise.
Thanks
Mandeep
Posted on Jun 03, 2008
  • Mandeep  Singh
    Mandeep Singh Jun 04, 2008
    Getting to the dryer is tricky, coz , we need to dismantle the tub assembly. If you can lay your hands on the service manual for this dryer it would be a breeze to open it.
    Else i would suggest let the repair man do the job.
    Thanks
    mandeep
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
My 10 year old electric dryer (Whirlpool Gold Ultimate Care II) is making a squealing, rattling noise. It still heats up, but something sounds loose. I wondering if I should get it fix or replace it.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 19, 2011 | LG DLG2524 Gas Dryer
My dryer has started to make a loud rattling noise when drying. It works fine but the rattling noise is coming from the lower back part of the unit and nothing seems to be loose. What can I do?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | Maytag Dryers
Leaking from bottom on spin. also makes rattling
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 10, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer is making a rattling noise when in operation. Dryer is eight years old of so. Never heard this noise before.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Jun 13, 2010 | LG DLE2532W Electric Dryer
My dyer is making a rattling sound what is cause it to happen
Hi, Can you tell if the noise is in the lower front? It sounds like maybe the blower wheel has went bad. I can assist you further in this if you need.
Thanks
Vic
May 21, 2009 | Maytag MDG5806A Gas Dryer
Kenmore dryer making rattling noise
If the panel's clamps are broken it will rattle,for a quick fix i would use duck tape on both sides.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Kenmore 63942 Dryer
Hi my machine sometimes makes a loud rattling noise when its been used for a while. Its a bit concerning thanx tracy
May want to check your venting system to the outside. If the dryer cannot blow out enough heat outside due to the vent being clogged or kinked, then it will overheat causing panels and moving parts inside the dryer to get too hot and rattle.
Aug 26, 2008 | Dryers
Fisher and Paykel Dryer ED56 Noise
your rear bearubg is mnost likely failed. and the back plaer is now hitting against the drum.
Part number (Fisher & Paykel Dryer Rear Drum Bearing Kit Part 479317)
you can replace this eazily by yourself.
check that the belt is over both rollers as well.. sometimes they slip off one of them.. especailly if moved around.
but this rear bearing is very bad. If you can find a skateboard bearing. it will fit nicely too. a much cheaper replacement and works fine. must get a good quility one lol (but any flate bearing is fine if you can find some in your workshop or neighbours lol
Jun 03, 2008 | Dryers
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Open Questions:
Dryers Logo
157 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
