Monitor colour problem
Monitor color is changing to greenish while surfing
  • 7 more comments
  • Anonymous Jul 01, 2008
    it turns green
  • Anonymous Dec 10, 2008
    The Colors in my LCD are also randomly changing and running on my display.
  • Anonymous Dec 16, 2008
    how do you adjust the color
  • Anonymous Dec 22, 2008
    my 740T has the same problem, three months off warrantee and it alternates and flickers between a normal and blue / green tint meaning the red is dropping. very disappointed with samsung, would never buy a samsung monitor again especially since this was a TOTL model.
  • Anonymous Dec 24, 2008
    Not showing reds at all. Everything appears greenish. Orange shows as yellow and deep red shows up black. Please let me know how to fix this.
  • ixlives Dec 29, 2008
    Brand new, just out of the box and monitor is green/blue..... tried cable on my other hp and now that monitor is the same.....
  • Anonymous Feb 23, 2009
    I have the same problem with my MAG LT982s ... weak blues and greens .. no reds at all
  • mel_rulez Mar 31, 2009
    mointor is a green colour and i cant seem to be able to fix it
  • Anonymous Apr 27, 2009
    The color spectrum of my monitor has no red, only green. I have had it a week. Is there no setting I can change?? It started out OK.
I had exactly the same problem. Acer AL1917 dropping red intermittently, making a blue-green cast, then flicking back. I went into the menu and selected Reset. Seems OK now... will wait and see
Posted on Mar 20, 2009
  • 66 Answers
Could be loose connection, push-in the video connection and screw the cable to the video port properly.
Posted on Jun 03, 2008
Color shows greenish tint
Try a different video cable or make a careful inspection of the pins in the video connectors. Look for bent or missing pins. Your missing a color channel.
Jun 30, 2014 | Dell IN1910N 19" Monitor
How to reduce greenish colour on hp 1702
in the main menu of your display buttons on your monitor there is color settings red blue and green wshere you copuld adjust. it this helps please rate with comment
Feb 06, 2013 | HP Compaq 1701 17" LCD Monitor
The screen fonts at bootup are of green colour and the greenish is prominent after bootup also
The tube has aged. You can try to overvolt it, this will restore the correct colors for a short period. Use this time to save some money for a new monitor.
Aug 01, 2010 | LG Studioworks 700S 17" CRT Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
My compaq 7540 monitor settings menu automatically opens frequently and on the other side of the monitor means on the upper right corner of the monitor the color slightly greenish
about the settings menu it is the problem of the main system ic in the monitor.And about the colour on the right side corner pls change the ptc in the monitor .
Jul 21, 2009 | Compaq CV 7500 17" CRT Monitor
My monitor changes to greenish.
First check wether the monitor cable is inserted into the PC and monitor correctly. If that doesn't help, try another cable. If that doesn't fix the problem, please post back here.
Jun 07, 2009 | IBM T 85D Monitor
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Overall color change (greenish) 10 seconds at a time with multiple computers
It is due to dry soldering on the crt board. Try to resolder all the dry joints on the crt board.
May 23, 2009 | Gateway EV 910 19" CRT Monitor
Installed new color wheel not working correctly
Hi danny,
I also replaced the color wheel in my EP739 after the old one disintegrated suddenly. Colours were then all over the place. Actually, it looked like each colour channel was displaying all the colours of the rainbow!
Here is the procedure I used to solve the problem - maybe not as elegant as Marrie's solution, but it will not cause any damage, will most likely solve the problem, and you will be able to get everything back to the way it was if it doesn't work:
  1. Have the projector running and displaying a stationary picture. The right sort of picture to use is one that has a full range of brightness values from near-black to peak white. I used my lap-top as the source. Also, this way you can compare the projector's picture with the picture on the lap-top.
  2. Press the power button once. "Power off the lamp" dialogue box appears. Hold down the left arrow button until the service menu appears (takes about 8 seconds).
  3. Using the up/down arrow buttons, scroll down to "Color Setting" and press "enter".
  4. Scroll up to "Color Wheel Index". Make a note of the existing setting for later reference. You can change the Index setting over a range of 100 to 550 by holding down the left/right arrow buttons. As the setting changes, the colour rendition will slowly change, and at some point the colours will come right. Note that the changes are quite slow. Find the lower and higher settings where colour aberrations just start to appear, and set the Index mid-way between.
  5. If this doesn't fix the problem, return the Index setting to original. My original setting was 354 and the new setting was 461.
I do not advise touching any other settings in the service menu unless you have access to a service manual and know what you are doing.
Father Dave
Mar 08, 2008 | Optoma EzPro 739 Multimedia Projector
Computers & Internet Logo
882 people viewed this question
David Payne
David Payne
