Question about Woods INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR
Require the internal battery what type is it?
Many of these timers have a built-in backup battery that is not replaceable.
If the battery goes out, then the display doesn't light up and you can't work timer.
The Woods replacement for 49112, TD 1000 etc is the Woods 59377
They sell the new Woods 59377 rascal on the internet for $15-23
Lowes sells similar timer made by Utilitec >>> I bought that one, and it doesn't have any instructions included, so I took it back
Posted on Oct 17, 2010
Does my Pronto m 91 require internal thread battery terminals or the nut & bolt type of terminal ? Bill Cadman Grants Pass, OR
surely if you open the hood and look at the cables you will see what kind of battery it has .
Dec 14, 2016 | Cars & Trucks
What is the type and parameters of the internal cooling fan
The type of fan can be very different between two similar UPS.
The easiest way is to open the UPS and watch for.
Some UPS requires exactly the same fan, and if they take too little or too much current UPS think that it is wrong on the fan and alarms!
May 28, 2014 | MGE Computers & Internet
Power devil safe PDW5500 electronic digital
Take apart the unit if it appears to have an internal battery with no access hatch and replace it with a new one that is compatible. If you cannot find a replacement, you can always build your own battery pack.
Use the same battery type and voltage and solder them together if required. Make it clean with no potential for any short circuits. Do not mix old batteries with new ones. If you can find higher capacity batteries than what the vaccum came with, those will be fine to use as well. Just make sure they are rated at the same voltage level so that charging them wont require any modifications. Don't burn yourself!
Most middle schoolers and highschoolers can help you with this if you have any younger folks around you.
Apr 24, 2014 | Vacuums
Battery
The Casio Forester FT500WVB watch has an EL (Electroluminescent) backlight and requires one silver oxide button battery. The SR621W battery (also known as type 363) is recommended by the instruction manual for the watch. Note the suffix "W" means this battery is a high drain type which is suitable for powering a watch mechanism and the EL light as well for 2 to 3 years, depending on use of the light. "SW" suffix batteries are low drain and are intended only to power a watch mechanism, and not a light. Note also the "SR" prefix indicates the battery is silver oxide and not lithium. The SR type batteries do not use mercury and are therefore safer to dispose of when they are discharged. I have found the type SR626W (also known as type 377) battery is also suitable for the FT500WVB watch and it has more stored power and should therefore last longer.
Last, the Casio Forrester FT500WC looks exactly like the FT500WVB, but it is a different watch internally. The FT500WC has an LED light and requires two batteries- the SR920SW low drain silver oxide battery which powers the watch mechanism and the CR1616 lithium battery which powers the LED. The LED is brighter than an EL light and stays on longer than the EL light when activated. But the LED has a bright dot light source that some might find annoying.
Apr 17, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Date time not kept
Make and model of camera needed to answer question
Feb 23, 2014 | Cameras
How to charge battery
The specs on this camera say that it has an external charger. Sometimes the usb cord will also charge the camera, but not all the time (depends on manufacturer). You will have to contact Polaroid, most likely, unless you can find a generic charger at Best Buy, etc.
Here is some information about the internal charger of the camera from redpowers.com:
The Lifespan of the Polaroid T737 Battery The life of a rechargeable battery for Polaroid T737 Digital Camera operating under normal conditions is generally between 500 to 800 charge-discharge cycles.
This translates into one and a half to three years of battery life for the average user. As the T737 battery begins to die, the user will notice a decline in the running time of the battery. When a battery that originally operated the device for two hours is only supplying the user with an hour's worth of use, it's time for a new Polaroid T737 replacement battery.
Is it Possible to Upgrade the Digital Camera Battery to a Newer Chemistry? NiCad, NiMH and Li-Ion are all fundamentally different from one another and cannot be substituted unless the Digital Camera has been pre-configured from the factory to accept more than one type of rechargeable battery technology. The difference between them stems from the fact that each type requires a different charging pattern to be properly recharged. Therefore, the Polaroid T737 Digital Camera internal charger must be properly configured to handle a given type of rechargeable battery.
They didn't explain how to configure, but it should be in the software menu of the camera.
I found batteries for this camera on google, but couldn't find a charger. Looks like if you have the right type of battery, the internal charger (through the usb port) will work.
Good luck, thanks for using FixYa, and hope this helps.
Aug 20, 2010 | Polaroid T737 Digital Camera
Convert a Behringer BCF2000 to run on batteries?
The basic unit requires 10 watts at line voltage. Modifying the unit internally would be a disaster. You are better off using an invertor to drive it.
The internal supply will be a switching type and probably generate +/- 15 volts and +5 volts.
Feb 01, 2010 | Behringer Music
Battery life? replace? how much?
The battery for this player lasts 1Day(mp3) and 5-7hrs(video.)
You cannot fit a replacement yourself as you will have to take the player apart. Proffessional help is advisable. A replacement battery will cost around 15$.
And you can carry but cannot view documents on this player.
Here are the complete specs for your player
  • General
  • Width 2.3 in
  • Depth 0.4 in
  • Height 4.2 in
  • Weight 3.4 oz
  • Localization : United States
  • Packaged quantity 1
  • Digital storage media type None
  • Digital Player / Recorder
  • Digital player supported digital audio standards WMA, WAV, ADPCM, MP3, AAC
  • Digital player response bandwidth 20 - 18000 Hz
  • Digital player sample rate 48 KHz=8 KHz=11 KHz=32 KHz=44.1 KHz=16 KHz=22 KHz
  • Digital player signal-to-noise ratio 84 dB
  • Digital Player total harmonic distortion 0.05 %
  • Digital player ID3 tags support Yes
  • Digital player additional features Variable bit-rate compatible, WMV playback
  • Battery
  • Rechargeable Battery Rechargeable
  • Battery Enclosure Type Internal
  • Included Qty 1
  • Technology Lithium polymer
  • Battery 1 x Lithium polymer Rechargeable Internal
  • Battery Life Details Video playback 6 hour(s), MP3 playback 30 hour(s)
  • Capacity 880 mAh
  • Connections
  • Connector type 1 x Headphones Mini-phone stereo 3.5 mm, 1 x USB
  • Slot(s) provided None
  • Slot(s) Required None
Oct 05, 2008 | Philips GoGear SA5285/37 Digital Media...
Woods  INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR Logo
136 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
