Question about Honda Karcher G2400HH-R Pressure Washer
At the beginning the pressure washer was running but there was no power from the nozzle. I stop the gun trigger, remove the nozzle , it works for 1 minute and stop working again Now the washher pressure turns off on its own after 1 minute or less Honda 2400 psi
    Scholar:
  • 100 Answers
See attached link:
http://www.wmpcs.com/index.php?main_page=page&id=14
If you continue to have the problem you might have to purchase a new unloader valve, see attached link:
http://www.wmpcs.com/index.php?main_page=product_info&cPath=45_2&products_id=246
Posted on Oct 21, 2010
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
Motor is working but does not spraying the water and also cant remove main hose from both machine and trigger gun. what is the problem?
Hi Fahad:
I could be suspicious that the gun may be clogged.
If the hose and gun are pressurized the couplings should not be able to be dis-connected. The pressure should be released first by shutting the motor off and then squeezing the trigger to allow the water to drain.
May I suggest that you first try a different nozzle on the gun, and if it still won't work, a "dismantle and service" procedure would be the next step.
Mar 13, 2016 | Garden
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Power washer 12poe-170 takes 5 minutes to build up max pressure
not a new gun but the nozzle removed and cleaned out. Pressure units work through a regulator that is controlled by the flow through the nozzle. If there is insufficient flow the regulator unloads the pump. It the flow is too low the regulator opens and closes as the pressure fluctuates. removing the blockage allows full flow and full operation of the regulator.
Jun 10, 2013 | Powerwasher NEW 12POE-170 1700PSI Electric...
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.
Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely.
Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles.
I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!
Don
Mar 23, 2012 | FAIP Garden
When the spry trigger is pressed the engine boggs down and stops. Is there a relief valve stuck maybe.
This issue is caused by defective unloader or debris trapped in spray nozzle or faulty gun. Easy to check. Check system with-out spray nozzle. The engine should not labor at all when you depress trigger without nozzle. If it labors/ dies faulty gun, if no labor, install new or clean nozzle (check for correct gpm for machine) and retest. If ok, you are done, if engine labors or dies, reduce pressure by turning pressure knob as required. If reducing pressure has no effect, most likely faulty unloader. Good luck
Oct 06, 2010 | Coleman Pressure Washer PW0881800
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
STARTS AND RUNS FINE BUT WHEN I START WASHING IT QUITS SPRAYING AND THEN BUILDS PRESSURE AND KILLS ENGINE
The reason it stops spraying might be a clogged gun, hose or nozzle-tip.
The reason for pressure buildup killing the engine might be a stuck unloader valve in the pump.
While you are checking each component of the "output" side, spray some penetrating lube into the "input" side of the pump (where the garden hose connects) and let it be working on the unloader valve.
Fix the spraying problem first:
Start at the nozzle and verify that it is open by using low-pressure air. Clean or replace as needed. Next check the hose (with nozzle and gun unhooked) and finally the gun/trigger mechanism.
All must be clear and open to perform correctly.
Next, pour a few ounces of power steering fluid (or similarly LIGHT oil) into the garden hose, attach it to the pump and turn on the water supply.
Leave the "output" hose, gun, etc. UNHOOKED and point the output port of the pump (where the high-pressure hose connects) towards a vacant, safe area.
Startup the engine and allow the oil in the garden hose to work its way thru. (About 1 -3 minutes of run-time.) Shut it down and attach the high-pressure hose.
Hope this solves the problem!
Oct 05, 2009 | Honda Pressure Washer PSI 3000
I have an electric power washer k3.99M. I just replaced the pressure hose and now the washer will not turn on. If I remove the unit from the water hose, it works, but when I hook everything back up, it...
This sounds like the hose is plugged or the nozzle itself is plugged. If the water cannot get through, the washer senses that the trigger is off and will not turn on the pressure. First just attach the hose without the gun and nozzle. If it pumps water, you know the hose is OK. Then attach the hose and gun ant try it. If it still works then you know it is the nozzle.
Aug 25, 2009 | Karcher Garden
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
Honda Karcher G2400HH-R Pressure Washer Logo
305 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
