Question about Whirlpool Dryers
Believe the belt that turns the drum is broke. how do you replace?
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 16, 2010
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
The inside drum quit turning. is there a belt that turns this and if so how do I get to it. I had the top open but could not see anything. The drum spins if I manually spin it so I know it is not bound up...
if you cant see a belt about 1/4" wide around the drum, there will be a mark where the belt was on the drum before it broke,remove front panel and restring belt around the drum,then replace front drum piece that holds the drum in place and then string belt around idler and motor pulleys and replace front cover
Mar 23, 2011 | Maytag PYE2300AY Electric Dryer
Hi I have a Beko / flavel TD162 W dryer . The belt broke so I replaced it yesterday , however when i opened it the drum was actually seized so I thought the back bearing but no it was fine . The front of...
I believe you will need to replace the drum glides since the drum rollers are good:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 16, 2011 | Dryers
Drum wont turn. Motor and blower run.
sounds like you broke a drive belt, remove the dryer shell and you should find the broken belt pretty easily you can also replace it yourself it is a relatively easy job......HAVE FUN ........YOU CAN DO IT!!!
Nov 30, 2010 | Dryers
Belt broke and drum will not turn
replace belt order belt using modle number,,,check tension pullys also for damage,,,,,,,,,www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Past few days, dryer got very noisy. Then drum
The noise is coming from a moving part. There are only a few that normally cause a problem. Also the dryer drum not turning freely is what broke your belt. Here is what I would replace. Drum rollers, Drum slides and idler pulley. You can check these parts before you replace them. If the drum rollers don't spin real easy, replace. If the idler pulley does not turn easy, replace. If the drum slides are worn, replace. Your model may be one with a front drum bearing. If it looks worn, replace.
You may be able to take dryer apart, try turning drum. Listen for the noise and notice if the drum is hard to turn. If so, you may be able to determine if the problem is in the front or back of drum. Keep on mind that the noise might have been the belt slipping due to the drum being hard to turn. Either way, when you have it repaired, it should run with the noise. Good luck.
Oct 16, 2009 | Kenmore 400 6943 Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
MDE5500AYW Drum belt
I dont think you broke the belt, I think it may have just come off the belt tensioner. Take the bottom of the back panel off and I think you will see it hanging in there. Just put er back on.
Nov 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Drum won't turn
it came off the tensioner or it is broke. pull the belt and see if it is not broke. if it is still loose around the drum, then it just came off the tensioner.
look at the manual on how to put back the belt with the tensioner.
tnx 4 using fixya,
drcool
Sep 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
