Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon ip5200 Service Error 6A00
My Printer is locked up, when a printed doc is sent a SERVICE ERROR 6A00 pop's up. The green/orange light flashes 12 times.
Can you help?
  • 4 more comments
  • Anonymous Jun 10, 2008
    I have the Error 6A00 problem on my Cannon MP830 printer.  The copy light and alarm light both flash and the window displays the error code.  Ink cartridges do not light up and the paper does not feed in.  This happened on a very humid day, if that has anything to do with it, but I am unable to resolve the problem.
  • louw780 Jul 04, 2008
    Canon Pixma IP5200 Printer: Green ligt is lashing, yellow light is flashing and when print job is send, "operator message is receive.
  • flo2 Jul 11, 2008
    Alarm & Copy button flashing with error code 6A00. Will not do anything. Locked up.
    I have turned off then on again to reset. I have disconnected from computer and reconnected. I have pushed reset button.
  • scad2k Jul 24, 2008
    Same problem. HELP!
  • Emgy Galopez Dec 03, 2008
    A600 and green and yellow light flashing.... on and off nothing works
    Exact the same problem with an IP5200
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon ip5200 flashes 12 times, n bottom feed light is on.
it is problem your printer is wast tank is full it is service error
Jul 14, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon printer mp830
I had the same problem with my Pixma MP830 printer giving me a 6A00 error indicator. I solved my problem. Hope this will solve yours too. I moved the printer head over to the left. I noticed two black pieces of paper or sponges attaced to a spring on the right hand side where the head is at rest when not being used. I with a paper towel absorbed a little of the black in off the paper or sponge like material. I found the two white long pieces held by the spring were forward and would move. I used a ball point pen and moved the closed piece with the spring attached to the rear of the printer and it remained there. I surmised it was out of place because when I started up the printer again my 6A00 error code was gone and my printer was working again. It took me a long time to get to this point (like 6 hours) but that saved me from taking my printer in and spending like $80.00 or more for them to take care of the problem. Hope this helps you fix your Canon Pixma MP830 printer or other models giving the same error code to you.
CALL ME DON W
Nov 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,928 people viewed this question
old marine
old marine
Corne Viljoen
