Question about Refrigerators
I have a Hitachi refrigerator model no, R - S31SVND. It has an automatic ice-maker. This afternoon I put some beer cans into the ice gathering section of the fridge and it stopped making ice. What should i do to revive this feature?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 112 Answers
SOURCE: subzero 500 series ice maker
It sound's like you have a faulty icemaker. The icemaker has an internal timer that commands the inlet valve on at the correct time. If it does not stop the command, it will continue to fill. When you shut off the system, it kills power to the icemaker and that is why the solenoid goes off.
Posted on Oct 18, 2008
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Ice maker... its makes the ice but then doesn't dispense it the whole way.. its like it gets stuck sitting there and doesn't want to keep rotating, i have to lift or "reset" the wire ... its a model # M1
Good Afternoon Sean, thanks for your inquiry!
I understand that your icemaker is not dispensing ice and it gets stuck rotating. You have provided me with a model number of M1 and I was unable to locate any information on that icemaker. May I have the model number of your refrigerator? You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Mar 15, 2015 | Frigidaire Ice Maker / Icemaker 5303918277...
Is there a complete ice maker for EI23BC56IS3
Good Afternoon Friend,
I understand you want to know if there is a complete ice maker for your Electrolux refrigerator, model# EI23BC56IS3. Your particular model's ice maker is in parts and would need to be assembled. It does not come as one complete piece. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux EI24WC65G Wine Cooler
Fghb2844lf1 ice machine is not work
I understand that the ice maker in your Frigidaire refrigerator, model# FGHB2844LF1, is not producing ice. I suggest turning your ice maker off and taking out the ice tray and dumping any ice that is in the tray. Wait 3-4 hours. Dry the tray out and put it back into position. Turn the ice maker back on. It will take anywhere from 2-3 hours for ice to produce. If your refrigerator is still not producing ice, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Refrigerators
How do I turn off ice maker
Good Afternoon Rsimmon5,
I see that you are trying to turn off the ice maker to your Frigidaire refrigerator, model# FRS6R5EMB. You will be moving the signal arm to turn your refrigerator off.
To begin ice production, lower the wire signal arm to the DOWN or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, raise the wire signal arm until it clicks and locks in the UP or OFF position.
If you have any trouble with your ice maker continuing to make ice after this, I recommend contacting either the manufacturer or an authorized technician in your area. Hope this helps.
-Best Regards-
WP
Apr 05, 2014 | Frigidaire FRS6R5EMB Side by Side...
Ice maker quit working
Good Afternoon Kevin,
I understand that your Frigidaire refrigerator, model# FRS26R4A, is not making ice. There are a couple of things you can check. First, check the wire signal arm to make sure it is in the "down" or ON position. The ice maker turns off automatically when the ice container becomes full. To stop the ice maker, lift the wire signal arm until it clicks, and locks in the "up" or OFF position. Second, check to see if the water dispenser is dispensing. You might need to change your water filter. It's recommended you change it every 6-8 months. The other thing if your appliance is not dispensing water is there might be a kink in the hose or maybe the water supply has been cut off. Hope this has been helpful.
-Best Regards-
WP
Mar 27, 2014 | Frigidaire FRS26R4A Side by Side...
Fridgidaire ffht1817lw8 noisy operation
Good Afternoon John, thank you for your post! Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become a common hum in your home. This noise also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable.
Listed below are descriptions of some of the most common sounds you may hear, and what is causing them:
A. Evaporator: The flow of refrigerant through the evaporator may create a boiling or gurgling sound.
B. Evaporator Fan: You may hear air being forced through the refrigerator by the evaporator fan.
C. Defrost Heater: During defrost cycles, water dripping onto the defrost heater may cause a hissing or sizzling sound. After defrosting, a popping sound may occur.
D. Automatic Ice Maker: If your refrigerator is equipped with an automatic ice maker, you will hear ice cubes falling into the ice bin.
E. Cold Control & Defrost Timer or Automatic Defrost Control: These parts can produce a snapping or clicking sound when turning the refrigerator on and off. The timer also produces sounds similar to an electric clock.
F. Condenser Fan: If condenser coils are located underneath your refrigerator you have a condenser fan. You may hear air being forced through the condenser by the condenser fan.
G. Compressor: Modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound.
H. Water Valve: If your refrigerator is equipped with an automatic ice maker, you will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle.
I. Drain Pan (Non-removable): You may hear water running into the drain pan during the defrost cycle. The drain pan will be located on top of the compressor for air-cooled condensers (black coils on back of refrigerator).
I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Aug 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Jenn-Air side by side refrigerator. JRSD209T. Water fills up the ice shute and runs into the floor. What stays in the freezer freezes in the chute. What do I need to change to fix this problem
From your description I'll gather you're not getting ice cubes either and need to replace the ice maker
Part # D7824706Q on the diagram labeled "Lights and Ice maker" it's item 1
This is from Sears so you can order and have it delivered to the house
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2295HES/1266/0165000?pathTaken=
Jan 01, 2011 | Jenn-Air JCD2295HES Side by Side...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water comes automatically to the ice maker
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Jan 10, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
