Question about Roper RAS8445KQ Top Load Washer
Spin cycle is not working . All other cycles are working.
  • Roper Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 16, 2010
The Spin Cycle does not work
Suspect that the Timer module is faulty as it does not move automatically to the SPIN mode.
You need to try with another program cycle to confirm or otherwise replacement is the only option. check on cost and options..
Jan 16, 2013 | Washing Machines
This is for a Whirlpool washer and dryer thin stack. All four of the wash cycles work AND all four of the spin cycles work, but the rinse cycles do not work. I have to manually skip it forward past the...
I would suspect the water inlet valve as being the problem,if it drains the water and spins the lid switch is going to be good.The thing exclusive to rinse cycles is that they only fill with cold water,and that is what i suspect the problem being is that it's not filling with cold water on the rinse cycle because of a bad water inlet valve.
GENE
Sep 12, 2011 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Spin cycle
its sounds to me that the bearings are going, it would show more in the fast spin Close Ireland bye bye
Nov 21, 2007 | Frigidaire GLTF1670A Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
247 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
