Question about Nintendo Wii Console
No power to console; turned it off, won't go back on again. have tried unplugging and leaving for 10 minutes, but just won't go back on again.
  • 30 Answers
Does it have the red light on? If so, something is wrong with the console, but not sure why. If not, it's probably your power cord or block.
Posted on Oct 16, 2010
Power turned off but on charger over night won,t turn back on
Take out the battery, disconnect the charger, leave everything off and unplugged for 5 minutes. put it all back together and try turn it on again. If this does not work, there could be something deeper that is wrong. Might need to take it to a service center
Jul 13, 2014 | ASUS Computers & Internet
Will not turn on
Try holding the button a few seconds if its yellow its in standby it its green its on if not try using the controller power switch in the upper corner hold it for 3-5 seconds and see if that helps.
Nov 20, 2011 | Nintendo Wii Console
After fixing Wii console power light is not getting on ? what next
Did you open up the Wii console and perform self-maintenance inside of it? If so, you may have caused damage to a vital component needed for the Wii to work properly. Regardless, if the Wii light isn't turning on, unplug the power cable from both the Wii and the wall and leave it unplugged for a couple of minutes. Plug it back in and check again.
If it still doesn't work, leave it unplugged for the rest of the night and try again in the morning. Beyond that, if it's still experiencing problems, call Nintendo. Don't tell them that you opened up the Wii console (if that's what you did) or they will note it on your file and the warranty will become void.
Jan 04, 2011 | Nintendo Wii Console
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
Want to play again and turn on wii Console no picture, why
You need to unplug the AC adapter from the wall outlet for 5 or 10 minutes (NOT from the Wii, you have to unplug it from the wall outlet). Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 15, 2009 | Nintendo Wii Console
Playstation will not read disk?
If it will not read any disc at all then you could have a failed laser in the unit. Try turning off the PS3, unplugging it completely from the power (only the power is fine), leave it unplugged for 2 minutes. Go ahead and plug it back in and try a disc again. If it still doesn't work you will need to call Sony at : 1-800-345-7669
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
Red flashing light, won't power on My PS3 60GB has just switched itself off in the middle of a game!! Red light is flashing on the front and it won't come back on!! What is the problem?
Try turning the power off at the back and leave it unplugged for 10 minutes.
How long has it been running for without being turned off to cool down?
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
