Question about Canon CanoScan 4200F Flatbed Scanner
Windows 2000. Scanne worked great for 2 years. I installed a 1 1/2 terra byte external hard drive attempted to move the canon files to the external. The scanner would not even come on. Then I copied everything back to the D drive. Still no help. It keeps calling for CNQL3203.Dll. I search the entire system for the file and cannot find it. It is not even on the install disk.
  • 712 Answers
It is caused because you tried to move an installed file. During such a process, some files go missing which can't be retrieved even if you move it back. Simple searching will not show you the file in the installing disc, as it will be extracted only during the installation process. The fix is simple. Uninstall the installed applications (relating to the scanner) and install them again. And never select the installing location to a removable drive. Keep it in the internal HDD only.
Cheers. Thank You.
Posted on Oct 16, 2010
I got the error performing inpage operation on my hp external hard drive. I am running a chkdsk on it and it is now on stage 4 of 5 but just blinks at 0 percent. The external hard drive is blinking like...
if its a large 2 terra byte hard drive it will take quite a long time while the chkdsk utility perfoms the check
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps
Jul 26, 2012 | Western Digital Retail Hp Simplesave 2 Tb...
I originally set up the drive with a windows XP 2000. When I plugged it in to my new windows 7, it wouldn't work. It shows the drive is maxed out, and I can't access it. I had used less than one half of...
How many files are on the drive? Are they in folders? The FAT formatting normally used for these drives limits the total number of files unless the files are in folders. I think the value is ~500 items - this is due to the minimum bytes to store each file. (If the files are in folders you can stack 500 items in 500 folders.)
One thing to try is to move the files to your computer, and then return them to the flash drive. (Formatting the drive after the files are safely on your computer is an option.)
Good luck.
Jun 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hello i have a dell mini 910 and it has no space on it. i've heard of dual booting. how could i save, install, and run programs from an external hard drive
using an external HDD doesn't require dual booting.
First connect the external drive, and copy files to the drive that don't require and applications to be installed (MP3s, Avi Videos, Pictures)
Then you can delete the files from the HDD, this will immediately give a boost in performance. Generally, most games run a an Atom powered system don't take a great deal of space, so moving applications to the external drive likely would not be gratly beneficial as keeping data files there.
Dual booting by the way, is the process of installing 2 operating systems on a computer and being able to boot to more than one version. (Windows XP and Vista for example) of Windows and another OS (XP and Linux)
May 07, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
I have a 1 terra bit external hard drive . I edited music from a pc to my external hard drive using cd's & lps. I've been having problems with putting my music library in my new laptop computer. One...
Your installed music library in your external hard drive might not be supported by your media center on your new laptop, try to convert the files where the software are supported by your media player. try convert Master software, you can download it free then convert your files
Nov 01, 2009 | Seagate Free Agent Go Small 12 GB USB...
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
Problems with transferring files
I think I know which limit you have hit then. The maximum size for any single file on a FAT32 system is 2^32-1 bytes which is 1 byte less than 4GB (binary version of the number, not decimal) or 4,294,967,295 bytes.
Apr 03, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Partition external hard drive
Yes a 1 TB externald hard drive can be partitioned. Yes its safe to store files on the drive and remove them from the computer as long as they are not files that are part of the windows system. Its not necessAry to have them on the pC and on the drive but of course its safer if you do.
Jan 18, 2009 | Seagate FreeAgent Pro 1TB External USB...
I am getting a message that my drive d has low disk space available please help me..
If you're D:\ is a hard drive, you can delete non needed data to free up hard drive space. At today prices for hard drives you might consider buying a larger size drive. Like this drive. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117008
This is a PATA/IDE drive. Seagate warrants their drives for five years. You will not run out of drive space any time soon.
Windows XP description of low disk space. http://support.microsoft.com/kb/285107
If you hard disk is a serial ATA SATA drive you can increase its size by upgrading to this drive. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=117007
Mike
Jun 14, 2008 | HP Computers & Internet
Toshiba 500GB External Hard Drive Fails
It is a problem with windows xp. *.avi files in windows may cause the problem.
Solution:
http://www.moviecodec.com/topics/3588p1.html
Feb 19, 2008 | Computers & Internet
Canon CanoScan 4200F Flatbed Scanner Logo
32 people viewed this question
old marine
old marine
