I have purchased an estate house with a weso hsk-125 coal stove and I need to find a manual for it to make sure i use it properly.
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: looking for manual for keystoker
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html Helpful?
Posted on Dec 31, 2010
I am looking for a manual for an Atlanta Stove Works Homesteader Model 340ADG wood/coal stove that has been installed in a house I just moved into but has never been used.
Hello John,
Here is a manual for your stove, you can also call the phone number # 340ADG Here's a bit of history about your stove; Atlanta Stove Works there's even a PDF about a slightly different stove on this site.
Good Luck!
Rich Lilja
Jan 10, 2017 | Home
I need instructions for placing ceramic coals on a Cannon inset gas fire 26730G
Go to the wed site I Think stoves own cannon you should be able to your make of fire and down load a manual show how to replace your coals
Dec 06, 2016 | Heating & Cooling
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
I have a new Buck STove Hybrid (coal and wood). The brick liners in the ceiling are loose and frequently are dislodged when feeding wood. Why is it designed this way.
I would suggest contacting the manufacturer at this link http://www.buckstove.com/contact-us.html in order to get an answer to your question. Each stove manufacturer has their own way lining the stoves. Make sure you have your model number and serial number of your specific stove prior to calling the manufacturer so they can give you an informed answer. Good luck.
Do you have questions or comments
Jan 09, 2014 | Buck Stove Home
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
I need a manual for Monarch 24PY-2SW Kitchen Heater
Sorry this item is not in my area of expertise.
Nov 28, 2011 | Office Equipment & Supplies
How do I use the stove. We bought a house with a anthrasite stove, but we do not have an idea how to start it
Not sure which model you have, Reading Stove Co makes the anthracite model. Here's a link to their website http://www.readingstove.com/ Click on the Coal Stove Safety Tips tab and look for your model under Owners Manuals.
I hope all of this will be helpful to you.
Mar 11, 2011 | Heating & Cooling
My Dimplex coal effect black stove won't work. The problem started quickly. One time it worked, next it didn't. I have changed the fuse so that isn't the problem. Although the stove is about 12...
My Dimplex coal effect black Problem with the Dimplex Compact Electric Flame Stove Heater My Dimplex coal effect black stove won\'t work. The problem started quickly. One time it worked, next it didn\'t. I have changed the fuse so that isn\'t the problem.Although the stove is about 2yaer old, I have only used it about five times as it is in my drawing room that I sit in rather infrequently.I do hope you will be able to advise me the source of the problem.Thank you. salvador -
Oct 31, 2010 | Ovens
After installing the pellet stove,the stove seems to 'burn up" the pellets to fast not creating a "coal bed ',no real heat is going in the house.It is a breckwell big E mod. 55'000 btu...
Not sure what is happening but if the pellets are burning too fast that tells me you have to set the air flow while they are burning. Even a wood stove will burn to fast if there is too much air . There should be a setting for the air flow on all stoves and some times it should be almost closed. if it continues i would contact the stove seller and ask them.
Sep 04, 2017 | Heating & Cooling
Heating & Cooling Logo
428 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
