Rubber focus ring can be purchased in ebay. The rubber ring may be attached to the lens with glue. Use denature alchohol between the rubber and lens to remove the rubber ring. It can be stretched little. Once removed, clean any glue on the lens and stretch the new rubber ring and install.
Assure the ring gasket is in place under the hood.A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Please look under the hood, with the tank removed. There must be a black ring gasket (rubber) on the large tube at the front corner. That gasket seals the tank to the motor suction tube. If it has fallen off under the hood, the vacuum will be minimal.
Washer tub is probably very dirty from excess soap suds. These washers have no way of cleaning rinsing themselves off so they will have to be disassembled and cleaned out to remove the odor. That's about a 2 to 3 hour job. Be sure to replace the rubber seal and the shaft seal to prevent leaks.
