Question about Lanzar MAXP64 Car Speaker
How much air space is need for a sealed encloser
    Scholar:
  • 127 Answers
Are you sharing the air space or building a divider to give each driver its own air space
these speakers or not made for low end bass these woofer are meant for mid bass high bass
  • 6.5'' High Power Subwoofer
  • Non-Press paper Cone
  • Specially Treated Foam Edge Suspension
  • 1.5'' High Temperature Aluminum Voice Coil
  • Magnet Weight: 40 Oz
  • Impedance: 4 Ohm
  • Fs: 80Hz, Qms: 4.05, Qes: 1.3, Qts: 1.2, SPL: 87(dB), Vas: 6.8(Cuft)
  • Mounting Depth: 3"
  • Rubber magnet Boot Cover fers are
  • there is only 3 " of mounting depth needed i would build you door pannel out fiberglass a door pod and mount them on the door if you have a factory speaker there . then run to the amp and turn the x-over on to high pass and them use them as a mid bass driver up front for the front sound stage for get about them as a subwoofer get the lanzar 10's or 12's
    i mounted a set of ma audio 8" subs on my 03 s-10 door the speaker fit in the 6.5 location had to trime the door metal and space them out a little cause the 4.75 mounting depth.it worked and then i ran the them in 2 ohm stereo to my 4 channel amp and used the high pass crossover to run them as a mid bass driver works great for me . ma audio 500 watt dual 4 ohms 8" subs each i had 250watts to each sub.
    you could build a small enclosure just big enough to fit the 6.5 woofer you could build a dual camber enclosure like 8wx5dx8h internale air space would be 0.18
    15 wx5dx8h would give you 0.347 share the air space this is internal air space
    caraudioquestion@gmail.com
    Posted on Oct 16, 2010
    How much air space is needed for lanxar max st 15d
    it depends on the type of enclose you are building and number of drivers .. you can build them and share air space or build it to were neither sub shares any air space.. if you buy a prefab enclosure for your 15s what ever q logic or q power or any other manufacture choses to build a universal port or vent or sealed box will be just fine.
    which type of enclosure are you looking for ..
    port
    vented
    seal
    isobaric
    1.6 cuft to 2.5 cuft per subwoofer check out the sub boxes from qpower and there specs for 15"BASS15 3HOLE 40 1/8 x 21 x 21 x 17 2.5cuBASS15 4HOLE T 42 x 18 x 18 x 16 1/4 1.6cuqpowers specs from there website
    radiorepair@windowtintingin239.com
    Oct 29, 2013 | Car Audio & Video
    How to make a ac unit get down to 40 degrees
    You can't get an a/c unit to get to 40f unless you bypass its thermostat and have it in an enclosed, small space. It isn't designed as a chiller.
    Apr 26, 2012 | Frigidaire Heating & Cooling
    How much, cubic in., air space minimum, sealed encloser and also opitum for sealed enclosure? Speaker is 10in. , 4ohme, CJ-25PL193A Thanks Kevin A.
    This really depends on the subwoofer. All subs are NOT alike. I would recommend visiting the manufacturers website for more information. Typically 1-1.5 cubic feet works with most 10 in subs. But again, please check the manufacturer for more specific instructions.
    Sep 06, 2011 | Panasonic Car Audio & Video
    The smell is bad. What kind of venting do I need in the garage for All Pro 50,000-85,000 BTU/HR? Does the bad smell mean I;m in Danger?
    If you run a propane heater in an enclosed space, such as a garage, you can pass out and die from carbon monoxide poisoning - as well as just a lack of oxygen from running a high-power propane flame. Yes, I would say you are in Danger.
    Nov 11, 2010 | All-Pro Propane Garage Shop Heaters - All...
    How much air space
    Air space needed around the sub is a minimum of 1 inch, but 3-7 is preferred. If you get too big you can get an echo sound. Sealed is my preferred box - it generally gives you the deep base thumping you are probably looking for.
    Hope this helps! Rate my solution!
    Jan 05, 2010 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
    What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
    Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
    Kicker recommends as follows.
    0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
    So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
    Rule of thumb and something to think about.
    The more air space in the sub, the less power you can run, the less air space, the more power you can run.
    For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
    As well, the smaller box will be louder, But not sound as good.
    Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
    Can I mount a window unit with no outside access
    You could/can, but don't forget that (a) there is a good chance of heavy condesation, so size pan appropriately, or drain...and (b) The enclosed space where the drip pan is, is going to get quite warm. Hope this helps
    Jul 13, 2009 | Frigidaire FAC124 wall/Window Air...
    Jenn air fan comes on with rear burners (elec) can I disable?
    Perhaps, but sound safety says no. This generates a lot of heat in an enclosed space; the fan may be a nuisance but it is needed to keep the unit from getting too hot. Hope this helps!
    Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
    Lanzar MAXP64 Car Speaker Logo
    371 people viewed this question
    Top Lanzar Car Audio & Video Experts
    Radames Pagan
    Radames Pagan
    Joe Alexander
    Joe Alexander
    Chris Ward
    Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
