Question about Timex TX6490 Wireless Thermometer with Alarm Clock
I have a TX6470 and cannot receive the outside temp on the inside unit
  • 17 Answers
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Posted on Oct 21, 2010
  • conorp29 Apr 03, 2011
    i have done that. i have made sure channels are set to "1"...... i let it "search" for a few hours. no outside info from the remote..... what am i doing wrong?
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Outside temp battery quit yesterday. replaced batteries inside and out. outside temp will not show. what to do?
  • Remove batteries from both units
  • Install batteries in outside unit. Allow time for it to initialize and begin transmitting data.
  • Install batteries in inside unit. You should see outside temperature displayed. If not, there may be a problem with the outside unit.
Mar 18, 2018 | Measuring Tools & Sensors
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
My outside (transmission) unit is reading 20-30 degrees above the correct temp and sending the high readings to the inside (receiving) unit.
Replace the valve body. Newer units, you can replace the internal wiring harness. It comes with the temp sensor.
Feb 14, 2015 | Cars & Trucks
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
Hello The instructions supplied have several misprints and errors. For example it says the units need different batteries (AA and AAA) when clearly the larger ones wouldn't fit. Also it refers to using...
Hello Peter. I have just purchased a tx6470 and have had exactly the same problems.
Just subsitute the up/down buttons for hr/rcc.
The 1 2 3 positions are the channels that the outside unit transmits on,you can check this by looking at the inside display where it shows ch in the outside display.
Regarding the city code just make a guess to a large city near you, the British cities are lumped together London is Lon Glasgow is Gla Edinburgh is Edh.
The day Do. I did a reset of the date and it cleared to the correct day
To get the outside details to reappear, remove and refit battries from inside unit and reset everything.
Regards Stewart.
Dec 26, 2010 | Timex TX6490 Wireless Thermometer with...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Timex TX6490 Wireless Thermometer with Alarm Clock Logo
1,219 people viewed this question
Top Timex Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Timex Measuring Tool and Sensor Expert? Answer questions, earn points and help others
