Question about Sony VAIO Digital Studio PCV-RX650 PC Desktop
Two beeps when powered up, screen stays black. Ive removed the RAM cards an reseated them, switched them around and removed a few-----several times now. What next? Could it be the battery on the board itself?
    Master:
    Sergeant:
  • 381 Answers
Unplug the power cables from motherboard.
then replug. try that. you RAM could also be faulty, which in that case you might need to purchase new Ram
Posted on Oct 16, 2010
Installing graphics card
try reseating card (remove and reinstall)
Mar 07, 2014 | Alienware Nvidia GEFORCE DDR5 GTX 460M...
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Gateway PC GT5028 cpu fan comes on and stays on, but the computer does not boot, the screen is black and there are no beeps. I have replaced the power supply and the video card, but no joy. I also...
Just try putting your memory stick 1 at time, then on the pc, check each memory likewise mentioned. If this dosn;t work, trying taking out all the hardware attched to the motherboard, including hard drive, cd-rom. Now just try with to on your motherboard with basic hardware, video card, single ram. Hope you will find the problem, isf it is mainboard...best of luck.
Sep 17, 2011 | Computers & Internet
Computrer beeps several times when it starts
Depending on beep pattern it is trying to tell you that you have faulty memory or a graphics card problem.(normally)
If you have been inside your case / moved pc directly before this. Then suggest you gently reseat graphics card.
If you have added memory remove it, reseat original mem.
Dec 31, 2009 | Dell Computers & Internet
My acer will power and then beep 3 times is this a hardware probl
Try removing the ram , if more than one stick, one at a time. Or try reseating the Ram.
Dec 26, 2008 | Acer Aspire 5100 Notebook
Black screen at start up
Isolate the problem in the following order:
1. Make sure that your display monitor is working fine by checking it on another computer. Try to check the display cables from the PC to the monitor as well and make sure they are connected properly.
2. Check the RAM. If there is a problem with your system RAM, it will normally give certain indications like a series of beeps. Try to power on your PC without any RAM installed and you should hear a series of beeps. Count it and try to compare it by turning on the PC with the RAM installed. If it gives the same number of beeps with the RAM installed, then you most probably have a problem with your RAM. Sometimes, this problem could be resolved by reseating (removing and installing) the RAM. Take note that you should unplug the power cable before performing this step.
3. If your system has a built-in VGA display then skip this step. If your desktop has a VGA Card (the one connected to the monitor) then try to reseat this as well. Most of the time, especially on compaq machines, the VGA card has a tendency to get loose during shipment.
4. On rare cases, i encountered problem with the power supply. Check that the input voltage you're using is correct. Some desktops have 220/110V switches on their power supply. If it is switched to 220V and you're home electricity is 110V then you'll get undervoltage condition and therefore improper voltages will be produced. Please make sure about your home electricity rating, as making mistake here could cause a damaged power supply.
Nov 12, 2008 | Computers & Internet
Computer won't boot up. screen stays blank
Open up the PC and reseat any connector and modules a few times. Concentrate on the RAM and Video Card if it has one, removing and reinserting them at least 5 times.
This process cleans all the contacts and ensures that everything is properly plugged in.
If it still doesn't work then there are a few possibilities. The three components that have most likely failed are power supply, RAM (memory), or motherboard. If nothing happens, no lights or beeps, then it's probably the power supply. If the machines turns on but doesn't do anything then it's most likely the motherboard. If it tries to boot up but stops and gets stuck or if it stops at different times then the memory is most likely faulty.
Sep 02, 2008 | HP Computers & Internet
Hp pavilion dx8210us notebook
Check the ram on board, reseat it and try again. Sounds like a memory problem to me.
Dec 21, 2007 | ASUS M2NPV-VM Motherboard
Sony VAIO Digital Studio PCV-RX650 PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
