Question about Kenmore Freezers
Kenmore freezer model 1761 23.1 CU. Light in lid doesn't work. Replaced with new one but still doesn't work. What else could be causing this problem?
dididsaythat
  • 291 Answers
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Posted on Sep 20, 2007
  • 833 Answers
SOURCE: Chest freezer lid sticks in closed position
Yes, use silicon lubricant.
Posted on May 27, 2008
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
jyackle5
  • 8197 Answers
SOURCE: 253-21421104 Kenmore Freezer What is the
Your freezer is 20.3 cu.ft.
Good Luck
Posted on Aug 29, 2010
TerryTown
  • 292 Answers
SOURCE: what is the cu.ft. for Kenmore Freezer Model
The 3rd number after the 253 indictes your cu. ft. so the 3rd number on yours is 8, that means yours is an 18 cu. ft.
Best wishes,
TF
Posted on Jun 03, 2011
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
80 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
