Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
My recently bought used Craftsman DYT 4000 starter seems to have a polarity problem. When the battery is connected normally it rotates in reverse. when the polarity is reversed it engages but overheats
5 Suggested Answers
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
wadembly
  • 475 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 475 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
spekgt
  • 60 Answers
SOURCE: what engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
The only thing you have to do is have the size (diameter) and lenght (from cranckcase to end of shaft) of the shaft you have on your b&s and just go to your local Honda dealer , give them your shaft size and they should be able to give you all the options for a brand new motor . I really believe you can get a Honda 20hp model GXV620 or a 24hp model GXV670 that will replace your B & S motor .
Hope this help .
Posted on Sep 01, 2009
Why is my Craftsman dyt 4000 transmission slow in reverse?
change hydro fuid and filter see if that does it
Aug 27, 2014 | Garden
Craftsman DYT 4000 with 26hp Koehler and 48" cut. Tractor will start but will not run smooth. Need to have the choke pulled out and once you push it in the motor shuts off. Will not start if choke is...
try running a can of seafoam through it. you have a clogged carb passage or two. sometimes this works. if not youll need to clean out that carb
May 14, 2017 | Garden
My Craftsman 4000 dyt lawn tractor's electric clutch went out and when it locked up it choked the motor down....now everything is dead, there is not and "juice" going to the starter, the headlights will...
Sounds like the machine stopped charging,usually caused by a faulty rectifier/regulator or a bad connection to it.Try either charging the battery for an hour or so or you can put booster cables from your car to it and then if everything is ok you need to fix the charging system,or replace the battery[once they are sulphated they will not take a charge even if the charge system works].Check the connections to the battery as well and if you can test the tractor when it is running and see if the voltage stays between 14 and 15 volts.Let me know how you make out.
Jun 12, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Sep 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What engines will fit craftsman dyt 4000 (18.5 blew w/ 290 hours)
Hi there
Hope this help .
Sep 01, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
