Question about HP Pavilion dv1000 Notebook
DIsplay I have problems in my dv1000 laptop. the display is showing every thing very DIM. but whn i connect my laptop to a monitor every thing is ok. which part should I change? and how to do that? thank you Nasyr
  • 458 Answers
Http://h10032.www1.hp.com/ctg/Manual/c00312379.pdf there is the link to your service manual, You are going to need to replace the LCD Power Inverter.. It is going bad. They go for as little as 16$ on ebay..
It could possibly be the backlight going as well.. but the first step for your problem is to replace the inverter...
Posted on Jun 03, 2008
HP Pavilion dv1000 screen has gone extremely dim. changed the inverter and nothing. connected to an external monitor and nothing. what is wrong? HELP PLEASE!
Two things: video card issue or video card settings. Try to go to the power options configuration of your portable system. Adjust the brightness. If changes does not take effect on your portable's display as well as the external monitor, it is a video card issue. The last option of resolution is to re-install the video driver. Click the link below and choose the exact model of your computer. Try to download the video driver for your computer. Make sure that you have the correct driver for your operating system. If re-installing the video driver still fails, unfortunately you need to have your video card replaced. Usually the video card comes embedded on the motherboard. That means you have to have your whole board replaced.
HP Pavilion Models
Jul 05, 2011 | HP Pavilion dv1000 Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
HP DV1000/screen turns on then turns off.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 16, 2009 | HP Pavilion dv1000 Notebook
I have a HP Pavilion laptop ze4900. Every time I move th screen, the display either goes off completely, or it goes vey dim and I cannot read anything from it. The only thing I can do to get a display
You could have a defective screen - a defective inverter or a CCFL lamp.
  • Picture flickering with dim display.
May 03, 2009 | Computers & Internet
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Dell inspiron 4150 video dim
The empty slot is for a mini-PC card, usually a wireless network card. The 2 wires are actually the antenna wires that connect to the wireless card. The dim LCD may be a problem with the LCD panel display, video controller or motherboard. Try connecting the laptop to an external monitor by connecting to the Video Connector located on the back of the laptop. If the display on the external monitor appears to be normal, then your LCD display panel on the laptop has a problem. If the display on the external monitor is dim then you probably have a bad video controller card or motherboard.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 25, 2008 | Dell Inspiron 4150 Notebook
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
