Question about Belkin F5D7234-4 Router
All the LED lights are lit up except the wireless light. How do I get it back on
    Problem Solver:
  • 4 Answers
Unplug the router and your modem for approx. 2 min. then plug your modem back in let that reset. Once the lights on the modem come back on, then plug in your router.That should fix the problem.
Posted on Oct 16, 2010
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Internet led not lit
When the internet LED is not lit it is usually a problem with the ISP supply of broadband and not an issue with the modem or router. Other lights indicate a problem with these items.
t.
Jan 09, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
My wylan light dont light up
does the router work? put tape over all the lights so you arent annoyed by one light out on an older router.
check to insure a solid connection for all cables on the back of the router and each device connected to the router.
Jun 10, 2010 | Linksys Wireless-G WRT54G Router
My wireless light do not come on on the router at all.
The wireless light on the router lits up only when any wireless devices gets connected to this router. It is normal if this is the case.
But, if the wireless light is not lit even after any wireless devices gets connected, then in that case there are two possibilities:
a) LED behind the wireless light would have blown off.
For this, nothing can be done, though you may use the router till it gives you good wireless connectivity!
b) Reset the router (the reset button will be present at the rear end) and then re-configure with the CD.
Feb 01, 2010 | Belkin (F5D7230-4) Router (587009)
Status light isn't lit
If status light won't lit, there might be inside hardware problem in the router or maybe just the led is broken. Does your router still works just the status light wont lit or status light won't work plus the router? If the 2nd case is true then the router may be broken.
Jan 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wireless light not lit
The wireless functionality of the router is no longer working. The light is always turned on on all wireless routers
regards
Sandeep
Nov 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Describe your WGR614 wireless led not ON problem
go to the advance wireless setting and check if radio is disabled. if it is. enable it.
Nov 06, 2009 | NetGear WGR614 Wireless Router
Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
Jun 25, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Belkin F5D7234-4 Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
