My hitachi tv was normal with all digital channels available, but today it is only showing analogue. The remote will not allow me to get on to the digital menu button, and when i press TV/DVB-T it said "Error, cannot access digital services" Why??
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
SOURCE: Lost the digital TV viewing
There's a button stating DTT/TV and I didn't realise that they were 2 options. That's that. I had a stupid moment!!
Posted on Jan 20, 2009
  • 10 Answers
SOURCE: Hi Digital channels lost and will not hold
this is a fault of your digital tuner on the mainboard on some models they can be replaced alone others you may need to replace the whole board
Posted on Apr 23, 2010
Testimonial: "Thanks very much, I did suspect this however has put to rest the question of purchasing a brand new TV"
Obertelli
  • 3006 Answers
SOURCE: Samsung LE32N7 - Analogue channels ok - Freeview
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Posted on Sep 17, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Sony Bravia television froze
there is a fault within your digital tuner ! shutting the tv down with all cables and power disconnected may fix it but if not the tuner will need replacing. a cheaper option i would go for is to by a seperate set top box reciever .
best of luck
merry christmas
please take the time to rank this advice below
thank you
Posted on Dec 23, 2010
How to use PIP show another channel in TV mode
Dear Ariesky
Your TV does not support this. Normally when SONY refers to PIP, they mean you can display another analogue ( CVBS - RGB ) or Digital ( HDMI ) input simultaneously. They do not mean you can dislay two normal RF channels together, this would require a second tuner, which this set does not have.
Regards
Nov 28, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
May 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
How can I get an analogue signal on my LG3000 32in LCD tv? Digital input is fantastic, but no idea how to obtain analogue. Input is connected to a community arial and other residents get analogue with no...
According to the manual I looked at, this TV has only one antenna input. This means that analog is available if you let the TV do a full autoprogram of memory. It might take it several minutes to complete, but once its done you should have analog and digital if available. If you were looking for analog channel 5 then you would just enter 5-0 but digital channel 5 would be 5-1.
Nov 12, 2009 | LG 32LG30 32 in. LCD HDTV
Cant access the digital menu since the digital change over. Still recieve analogue channels 1 to 5 samsung lcd tv model LE32N73BDX
Hello Gregor_69
Lets see if we can get you sorted out. Please follow my steps and you will be back up and running in no time.
with you samsung remote make sure you press the TV button so that we are on a TV channel and not one of the other inputs.
Then press MENU
down to CHANNEL
go to AUTO STORE
you should find two option on there 1. air 2. cable
You want to highlight the air and START.
it will now give you 3 option
Digital & Analgue
Digital
Analogue
highlight the Digital option and START.
This will auto tune just your Digital channels. Once this progress bar has finished. You should find that all your Digital channel have returned to normal.
I hope that this has helped you out. If so then please leave a thumbs up
Cheers
Little Dish Fitter.
Oct 11, 2009 | Televison & Video
Jan 19, 2009 | Televison & Video
DIGITAL/HD CHANNELS
hi there, i have the LG 50in Plasma and just updated the channel connection by doing the following:
1. Make sure your remote is in "TV" mode.
1. Press the Menu button.
2. Highlight "Auto-program" (Should be the first item on the Menu)
3. Scroll over to "To Start" and press OK.
The TV will automatically search for all available analogue, digital and HD signals and may take a few minutes.
Once complete, it will return to the last program you were on and you will find all channels available.
To check the guide or the time, you need to press the "guide" button. Make sure your remote is in "TV" mode. Alternatively, pressing OK at any time shows you the time and channel that you are on.
Hope that helps!
jp
Sep 20, 2008 | LG 50PX4DR 50 in. Plasma TV
Grundig colour tv lost digital channels
there is prob in tv cicuit . memory ic may be curupt . if u r not a tv technician then connect a tv engineer
Mar 03, 2008 | Grundig GF70-600 TV
Dtv frozen
I had a similar problem and the way to solve this is to reset the set from the remote.  Set TV to standby and press Info, menu, mute then power.  The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter.  TV will turn off.  When switched on it goes into Plug and Play mode to reset the analogue and digital tuner.  Allow a full reset then you should be ok.
Peter
Oct 07, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
281 people viewed this question
Top Televison & Video Experts
Electro Med Services...
