Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fault with my dischwasher
I have a Fisher and Paykel DD603ss . The bottom draw is beeping F2 at me . What does this mean and can I fix it ?
  • 413 Answers
F2 indicates the motor is not rotating.The motor may be jammed or defective. Also , the motor rotation sensor may be defective
Posted on Jun 03, 2008
On the 2nd draw will start washing but not even a minute flashes the F2 error and stop washing, what this means?
Hi Francesca, The link below is a short youtube video on how to simply fix f2 on your fisher and paykel dishwasher.......CHEERS..
https://www.youtube.com/watch?v=qP_X9iG0f-g
Mar 29, 2016 | Fisher and Paykel Dishwashers
Cannot turn my fisher and paykel dishwasher off..keeps beeping and motors are running in both draws. I have taken the bottom draw out and it is dry.. I can only turn it off if I turn the house mains off...
I am assuming you infer that the bottom of the dishwasher is dry when you took the bottom drawer out. This means the floodswitch located on the power filter board at the bottom of dishwasher might be faulty. Do you get any Fault code on the display.
Apr 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disher washer is giving a signal F1 for repairs Model DD603SS
F1 means flood. Below is a link to a video that will show you how to fix the issue if you want to download the video.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Good luck
Mar 01, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel DD603ss ,bottom draw does not slide out easy,,,,
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Apr 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
DD603SS DISHWASHER PROBLEM
This is simple you need a new Detergent dispenser fitted in the bottom drawer. cheers
Mar 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
DETERGENT DISPENSER NOT EMPTYING ON DD603SS
Hi- It sounds like the solenoid on the dispenser is not changing the water diverter to the wash portion (cup) of the dispenser. You most likely need a new dispenser. Probably best to have a Tech out to change it.
Mar 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
198 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
