Question about Whirlpool Dryers
No heat.... Not sure if it's the fuses or the heating element. Need to know where those specific parts are to check them all. The dryer is 20 years old.
  • Whirlpool Master
  • 3,051 Answers
Hello there:
can you give the model number so i can send you the diagram of the parts and where they are located
normally this is going to be a heating element though
Posted on Oct 16, 2010
  • luvs2danceal Oct 16, 2010
    Whirlpool model # LES705XPN1
  • Michael Thomas
    Michael Thomas Oct 16, 2010
    To test it, use an Ohm meter or continuity checker, if no continuity it must be replaced. Unfortunately, you often can't tell if it's bad by looking at it because the heating wire can break in two but still look intact.
    President:
  • 3,074 Answers
This is a good website, hope it helps Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
We have a Kenmore electric dryer model 11066962501 that has stopped heating, can we get some help opening and repairing?
might be your heating element that is burnt check the model of your dryer then look upnon youtube to replace the heating element simple and cheaper can buy the specific element with the serial part number on the original part :)
Sep 21, 2017 | Kenmore Dryers
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
Dryer will not heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
There is a cover on the upper left on the back that houses the "Thermal Limiter"that you need to check for continuity with a multimeter. IF it's bad, replace with this part. Next, there is a thermostat on the rear heater housing that need to be checked for continuity and replaced if bad with this part. Then, check the heating element for continuity and replace if bad with this part.
Happy Holidays
Dec 14, 2010 | Frigidaire FER311FS Electric Dryer
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
Maytag dryer is not heat up. I think the heating
Hello, There are a couple of variations of the heating element, depending on the series number of your dryer.
Here's a link to the parts list and line drawing so you can verify the proper element you need.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=SDE4606AYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00005&componentDescription=REAR%20BLKHD,%20AIR%20DUCT,%20ROLLER&HTR%20(ELE)&documentId=M0510059&blt=06
If you have a Series 14 dryer, the element part number is #37001134, otherwise, there are a couple of other elements that your particular dryer might use, so check the model number and product tag so you can get the right parts.
You might want to check the element first, to make sure it is defective, before you order replacement parts, as it might be a faulty thermal fuse, which is much less expensive to replace than the heating element.
If you have a multimeter, you can check the fuse to see if it's failed. Be sure to turn the power off and unplug the dryer before removing the back access panel and checking the thermal fuse (see drawing in link above)
With the meter set to measure resisitance (Ohms) you can put a test lead on each side of the thermal fuse and if you get a reading showing no continuitity, then the thermal fuse is blown and needs to be replaced.
You can also check the heating element using the same method, again, make sure the dryer is unplugged before testing the continuity of the heating element, if you don't get a continuity reading, then the heating element is bad too.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | Maytag SDE4606A Electric Dryer
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Heating Element
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Are you certain that you need an element? There are numerous things that keep a dryer from heating.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
From this link you can navigate through the site to find the information that is pertinent to the model of your dryer, just enter your model number in the search box.
Below are some solutions to your dryer problem:
Temperature Switch, make sure a positive heat selection has been made. Then:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 07, 2008 | Kenmore 63942 Dryer
Hotpoint aquarius CTD40G dryer not heating up
Heating element
Thermal fuse
Wiring
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Thank you,
Dave E. (Illeagle)
Jun 23, 2008 | Dryers
Dryer operates but doesn't heat
If the power to the machine is OK then check these items.......
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust air flow has become blocked or restricted. Check the hose in the back of the machine for crushed hose. If OK, the vent pipe may need cleaning... check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Jun 22, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
