Question about Filter Queen Majestic Canister Vacuum
Filter Queen Model 99UK
My machine makes an aweful noise when I switch on, It sounds very poorly.
There is no suction at all
  • 2,794 Answers
What happens when you take the hose off?
Posted on Jun 09, 2008
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
Loud whining when the dyson goes on and off
Dyson vacuum cleaner - Strange noise troubleshooting.
WHISTLING NOISE
If you are getting strange noises from your Dyson vacuum cleaner, listen very carefully as each one is telling you something different. Look through the list and see if you can spot your strange noise.
If you are getting a whistling noise, that usually indicates an air leak (vacuum leak) of some kind.
If you also have a loss of suction, make sure you check for blockages, torn seals, or parts not fitted correctly such as u-bends etc.
A seal may also be missing so go through our poor suction troubleshooting and see if you can spot where the suction dies.
If you try all of that with no luck and have a machine that has a HEPA filter like the DC07 or DC14 especially, then remove the HEPA filter and check the circular seal underneath the HEPA filter. If this has moved even slightly this may be causing the whistling, try removing the seal and putting the filter back in.
The DC24 and DC25 ball models are known for this, you turn the machine off and it gives off a strange revving/flapping noise. To diagnose this properly then remove the HEPA filter (the one in the ball) turn it back on and off again. If the noise has gone then replace the HEPA filter with a new one. Go to our parts store to order one
POPPING NOISE
A popping noise accompanied by a really pungent burning smell 99% of the time indicates a motor failure with your Dyson vacuum cleaner.
This will involve a motor and usually a post motor filter replacement as it usually burns the post filter or at best traps that lovely smell in the filter for eternity.
Sometimes a popping noise is a bit simpler.
All Dyson vacuum cleaners are fitted with something called a bleed valve, if the Dyson becomes blocked the bleed valve opens allowing air to get to the motor so it doesn't get too hot and fail.
The bleed valve on most models makes a popping noise, clear the blockage and/or wash your filter and that should solve it.
Go to our suction problems page to troubleshoot it.
RATCHET NOISE
If you hear the dreaded ratcheting noise it'll scare your kids and pets and make you switch it off immediately. It sounds like a football rattle but worse.
The ratcheting noise only happens on Dyson vacuum cleaners with a clutch.
Don't know the difference?
Look at the two models below, the one to the left does not have a clutch the one to the right does.
Still don't see it? Look at the bottom left of each machine, the purple ones have a purple dial meaning it has a clutch (could be any colour dial) the yellow one doesn't.
Anyway, back to the ratchet noise. This usually only happens when something is obstructing the brushbar, it stops the brushbar to prevent the belt from breaking (clutch belts cannot be replaced by the customer) and makes the ratchet noise to warn you.
Removing the obstruction, like a sock or paperclip from the brushbar will usually get it working again.
If you remove the obstruction and it still ratchets, then unplug your Dyson and try turning the brushbar by hand. It should be quite loose, if not remove the brushbar by grabbing it and twisting and pulling until it comes out.
When you get it out try turning it if it is still tight then remove the end caps and check for dust or hair build up in the ends and also remove any hair built up around the brushbar. Spray some WD40 in the ends if necessary, put the end caps back on the brushbar and try again. If it is still tight to turn then I recommend a new brushbar.
If the brushbar is spinning freely by hand then the odds are it will require a new clutch. We sell these in our parts store one clutch fits most models, the only exception is any DC03 and the DC04 Zorbster model. We sell all clutches and brushbars in our parts store
POPPING NOISE
RATCHET NOISE
NO CLUTCH
CLUTCH
LOUD VIBRATING, SCREECHING OR REVVING NOISE
If your Dyson vacuum cleaner is making a loud vibrating or revving noise.
First thing to try is empty your bin and make sure there are no blockages, if that doesn't solve it then remove the brushbar and then try switching your Dyson back on again.
If the noise is normal again then it is your brushbar or possibly clutch if applicable. Remove the brushbar, cut off any hair, remove the end caps of the brushbar and apply grease, WD-40 etc to the bearings. Put the end caps back on again and try and spin it, does it spin freely? If not then the brush may need replacing.
If the noise remains with the brushbar removed then I'm afraid it is a motor failure and will need a motor replacement.
If your motor fails with this noise usually it is down to the filters not being washed often enough and dust choking the motor.
If you have one of the ball model Dysons, such as DC15, DC24, DC25 etc. this could be your brushbar motor, brush bar or the end cap!
Best thing to do is remove your brushbar and end cap and inspect them. Any obvious sign of wear or damage then replace them. Also inspect the part at the other end of were the brushbar sits (this is the brushbar motor and drives the brushbar) Is it worn or damaged? If so you will need a new brushbar motor.
Try switching it on with the brushbar removed and the brushbar motor turned off at the switch.
Is the noise still there? If yes then there is a good chance you need a new main motor (not brush bar motor)
If your answer was no, try switching it on with the brush bar motor on (will need to be in the leaned back position for this) Is the noise still there? Yes, then you will need a new brushbar motor.
If your answer was no again, then replace your brushbar and end cap.
One more thing to try with the DC24 and DC25 ball models is to remove the HEPA filter (the one in the ball) switch it back on and off again. Has the noise gone? Yes, then the HEPA filter needs to be replaced.
http://www.repairmydyson.com/#!strange-noise/c3ha
Mar 01, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Feb 09, 2011 | Filter Queen Majestic Canister Vacuum
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
My vacuum made a funny noise, the red light was on and so I turned it off. There are small sparks now when turned on
Sorry. It sounds like the suction motor is bad. The best thing to do is take it to a reputable vac shop.
Joe
Oct 25, 2009 | Filter Queen Majestic Canister Vacuum
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Filter Queen Majestic Repair Service Essex United Kingdom
when you mean overhaul is the motor not working or are you experiencing loss of suction or wha seems to be the problem?
Nov 09, 2008 | Filter Queen Majestic Canister Vacuum
Noise
The high pitched noise could be because the vacuum is loosing airflow. does the red light come on on the top? if it does ot emptythe vacuum, replace the cone filter, the secondary filter, and the batting in the top of the machine. also hook the hose to the top of the vacuum to make sure there are no clogs in the hose.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
