Question about Dymo LabelWriter Thermal Printer
The blacsk plastic cover to my Dymo 450 Tubo came un-attached. I have no idea to reattach. No directions or manual that explains how to reattach can be found.
  • alanhochman Oct 16, 2010
    I assume all Dymo label printers are hinged the same. I believe it only gets inserted from some certain angle or position, closed, 90 degrees, something? Try removing and reattaching yours and let me know please.
    Master:
    Sergeant:
  • 381 Answers
It just clicks in place.
very simple, unless you have let it fall and the plastic bits hae broken?
Posted on Oct 16, 2010
  • 1 more comment
    Brand new unit never used. Their are 2 pins that fit into the 2 holes from a certain direction. Can you please detail the process. Not looking to force or break.
  • Ikhlaq Hussain Oct 16, 2010
    align it and the push down gently or insert each side in first
    Does anyone have experience attaching and removing a Dymo top cover?
Replace the roll without black on white in DYMO 450 turbo
Most of the labels come with the black rolls already in place
i think you can just reposition the new labels on an old roll if the end isn't attached to the roll
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
How to disable DYMO label roll sensor in DYMO 450 turbo
The sensor cannot be disabled. DYMO printers (including the 450 series) are hard-wired to only work properly with genuine DYMO labels.
^CM
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
I have a Dymo 450 labelwriter. The platen release lever came off and I can seem to figure how to reattach it.
Here is how I fixed my 450.
You have to open the case, which invalidates the warranty.
First, remove the case front - http://global.dymo.com/img/compel/cRydqiFncuah2s6Pf5DxrozTFsn13Cnc.pdf
Undo 2 long screws (front) and 2 short screws(rear) underneath the case.
Remove side panels and base carefully as there are ribbon connectors to the base which might get damaged.
You will see two metal pins at the left front, partially hidden by a ribbon cable - do not damage the ribbon!
There is a notch on the metal part of the platen lever which goes against the front pin.
The hole in the metal part then gets pressed down until it catches on a groove in the second pin.
Do it in that order or it is likely to just pop off again.
You then spend several hours getting all the bits of the case to fit back together. Put the front on last.
Mine is now working but I accept no responsibility for what happens to yours!
Oct 25, 2012 | Dymo LabelWriter 450 Turbo USB Label...
The dymo 450 software says it needs win xp sp2 or better. I verified I am running win xp sp3.
Does the software not install? If not, go out to Dymo's website and download the software directly. They may have had an update since the version that ships on the CD. If it still won't install, give the support team an email. They have always been pretty helpful to me in the past.
Feb 17, 2010 | Dymo LabelMANAGER 450 Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Dymo Labelwriter 450 Turbo errors
450 label is stuck in machine. How can I fix this problem?
Dec 11, 2009 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter Thermal Printer Logo
66 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
