Question about Samsung LN-T4081F Television
My Samsung 42" LCD used to turn on quickly, now it takes a LONG time for the screen to show anything. It looks like it turns on, turns off, turns on, etc. 7-8 times before finally staying on--almost like its warming up. then, most times there are a few small orange dots on the screen??
    Brigadier General:
  • 8,909 Answers
Ageing capacitors usually causes this sort of problem. They change value going low capacity etc. A replacement flourecent display board may likely fix it as the display is taking too long to come on.
Posted on Oct 16, 2010
Samsung TL205 Camera turns on but the screen never shows any sign of light. Screen is not able to display anything. Can this model be reset?
Many times you can turn the screen off in the menu up settings. Some cameras have a physical button on the camera to do so. Look your camera over carefully, and read the menu settings in your manual. If you don't have that, scroll through all your settings and see if you've turned off the LCD.
Oct 13, 2014 | Samsung DualView TL205 Digital Camera
Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
Apr 20, 2010 | Samsung 226BW Monitor
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
SGH-T429 screen stays blank or dark
Friend, the problem is your LCD it maybe broken if it is then you need to replace it, and if not the flex connector is disconnected try to press tighten the LCD connector slot.to solve your problem
Jul 07, 2009 | Samsung SGH-T429 Cellular Phone
Vertical lines on my Samsung LNCT4665FX HDTV LCD
When you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Screen going black
We have the same problem...I thought you could change the bulb or lamp...but not finding out any info about it! HELP! This TV cost way too much to have problems this quickly.
Jul 27, 2008 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
Samsung LN-T4081F Television Logo
372 people viewed this question
Jerry Greenberg
Jerry Greenberg
