Microsoft Windows XP Home Edition for PC Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pc will not logon automatically after a recent windowsXP up date.
Ikhlaq Hussain
Level 3:
Master:
Sergeant:
  • Master 381 Answers
  • Posted on Oct 16, 2010
Ikhlaq Hussain
Master
Level 3:
Master:
Sergeant:
Answers
381
Questions
Helped
78997
Points
1135
You need to go
right click my comp
properties
then advanced sysetm setting
here you can change the logon process
When i switch it on it boot alright the after booting it tels me that logon process initilla
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Time and date are not set correctly
When the Date and Time is set in the BIOS setup or in Windows and when you boot up next time and the date and time are incorrect then the problem is a flat BIOS battery. A flat BIOS battery cannot keep the Data and Time stored in the BIOS. Replace the BIOS battery and set the Date and Time etc and the problem will be fixed.
3helpful
2answers
How to restore from crash
Hello.
There are two way to restore the system for your OS.
  1. Start PC
  2. Hold down or press the F8 key frequently.
  3. Soon a text mode windows will appear.
  4. Select SAVE mode using down arrow key.
  5. Enter
  6. Select your OS
  7. Enter again
  8. Wait
  9. Again an windows will open
  10. There will be two option YES /NO
  11. You will click on NO
  12. Now you can restore your OS
  13. Follow this links with pic
  14. Now you should select previous date
  15. http://support.microsoft.com/kb/306084
  16. OR http://bertk.mvps.org/
  17. Or http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
  18. Hope it will help you.
How do you update the time when changing to daylight savings time?
There is option in date and time settings. On the right side corner of your screen where date and time are displayed. Doubleclick to open
Click on Time Zone Tab and select your time zone and tick the option "Automatically adjust clock for daylight saving change"
Like the one in link
http://www.microsoft.com/library/media/1033/windowsxp/images/using/setup/tips/67446-select-automatically-adjust-clock.gif
Hope this helps
I'm cannot logon to WindowsXP Home Edition
Windows stores the activation information in two files in the c:\windows\system32 folder: Wpa.dbl and Wpa.bak. If those files are locked, or permissions are incorrect, Windows may not be able to save its activation information.
You might also want to check the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFTNT\CurrentVersion\Winlogon
(change Activation Required value to zero)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion
(change RegDone value to 1)
Boot into safe mode, click Start→Run and type regedit then check these values.
Where I will find a site to download the Microsoft WindowsXP Professional Edition Service Pack1 to install on the CD
If you are not set up to recieve automatic updates from microsoft you should change your settings to download these automatically and keep these up to date. To do this go to the start button, go to control panel, and then to security center. Click on automatic updates and follow the prompts.To get all of the latest updates go to the start button, go to all programs, point to and left click on windows update. This will start the process of updating your system. After some updates your system will need to be restarted,some do not require a restart. You have to repeat the windows update process a few times in order to recieve all of the latest updates.
Logon problem with HP Pavilion 783c desktop
probably running low on virtual memory try changing it or else there maybe some poorly written software or some kinda virus go to the MSconfig utility and disable unwanted software!
AUTOMATIC CHANGES TO DATE
Check your bios and set the correct date there also. If this does not solve your problem check for a virus by running a scan with your antivirus program. If you do not have an AV Software Program check out this one which is very good
www.free.grisoft.com
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
