1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format
via System > Format. (will take approx 3 1/1 hours). You may need
to have our AV cables ready if your using HDMI (in case HDMI isn't
detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup)
Testimonial: "Thank you very much, your solution was spot on and worked perfectly!"
SAFE MODE:
1. Place you finger on the on/off sensor leave it their untill you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
