Question about Dryers
My dryer is making a squeaking noise when I start it.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Oct 16, 2010
Maytag Gas Dryer, Performer G2300 Dryer starting making loud squeaking noises and then after about 2 dryer loads of this noise, the dryer just shut off midcycle. When I tried to restart the dryer, it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 07, 2010 | Dryers
Dryer started making a squeaking noise, then a thumping, then stopped altogether.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Oct 21, 2010 | LG DLE5977 Electric Dryer
My dryer makes a squeak noise when on...How can I fix this? It just started after about 1 year...
heatman101
Aug 28, 2010 | Asko T712C Dryer
Dryer making squeaking noise
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 11, 2010 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Dryer making load squeaking and squealing noise when starting it up..sometime it stops after awhile,but now it does it all the time.
heatman101
eue
Jan 22, 2010 | Maytag MDE508DA Dryer
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
My dryer just started to make a weird squeaking noise
heatman101
dhgj
Jan 27, 2009 | Maytag MDG6000 Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
