Question about Refrigerators
I was given a Black and Decker Nucool 1.7 cu refrigerator about a week ago. I didn't get a manual. Yesterday it started making a noise. It is well ventilated ventillated. The noise seems to be coming from the lower motor (left inside). It's like rattle. I pulled the white interior plastic screen out a pinch, and the noise went away, but for only a couple of minutes, then it starts back up. I normally put my gallon of milk in front of it. Do you think the milk got pushed up against the back which would make it rub up against the motor inside causing the rattle/vibration noise? I'm living off unemployment and don't have any money to spend on a new one and/or unneccessary repairs. Can you please help me? Cindi Hayes
aborcass
  • 2651 Answers
SOURCE: GE PDS20MBS
well it didnt get into the compressor area, but it definalty spilled in to evaporatr area, and landed on defrost heater. so yea your smelling boiled spoiled milk!!!mmmmm!!!! you would have to rermove back panel of freezer compartment to fully see the extent of spillage, as far aswhat got under refirig into drain pan, you can problably pull unit forward and remove back panel look into pan for spillage.
compressor would'nt be affected
Posted on Mar 05, 2008
SOURCE: Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Posted on Jan 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: it makes a loud noise , as if the ventilator was stuck
Are you coils dusty? Sounds too simple but they will do that if they are dusty. Also a failing compressor will do the same thing. You should buy or rent a probe and further pinpoint the noise.
Posted on Apr 30, 2009
HIRAM517
  • 59 Answers
SOURCE: Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Posted on Aug 19, 2009
xxchemlight
  • 144 Answers
SOURCE: Ventilation
for your exact model its needs 1 1/2 in on top and 2in on each side.
also here's the online manual as well.
Amana manual
Posted on Mar 25, 2010
Testimonial: "Thanks for the quick repsonse"
Black and decker refrigerator model BCFA27B not working
Check any defrost water hasn't got into the electrics and blown a fuse.
May 28, 2014 | Black and Decker USA Black & Decker 2.7 cu...
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Mini fridge wont get cold
How old is it? You proablaly need REFRIGERANT!!!
Jul 21, 2012 | Haier C-RNU1708B 1.7 Cu. Ft. NuCool...
Makes a snoring noise that goes away when you open the freezer door
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Jun 03, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
What size fuse to use in a Black And Decker NuCool 1.7 SqFt refrigerator? Model number is BNA17
3 amp but if that is blown theres 2 diodes near it the may be bad . i had the same problem
Jul 22, 2010 | Refrigerators
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
