Question about Amana 24 in. ADB1200AW Built-In Dishwasher
I have a Amana ADB 1600 AWW only been used about 4 times and it won't light up. Is there any kind of a reset button inside the door? Thanks, John Black
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Amana ADB 1200AWW
Try first unlocking the door latch with a small screwdriver, unplug power cord before working on the door lock.
If this does not work buy a replacement door lock, or get it replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
  • 96 Answers
SOURCE: fishy smelling dishes,
run some bleach in the D/W with nothing in it
Posted on May 02, 2010
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Forgot pattern need to unlock
If you've already set up a Google Account on your tablet:
1. Try entering unlock patterns several times right in a row. It *should* ask you to enter your Google Account info as an alternative way of letting you in, after which you can turn off pattern locking or set a new pattern.
2. If you set up a Google Account and the tablet isn't asking you for that info you can try to unlock it from this page:
https://www.google.com/accounts/DisplayUnlockCaptcha (this might only work on hardware authorized by Google, I'm not sure)
Keep reading for more details.
3. BUTTONS! There is usually some combination of button presses on boot that can get you into a "reset" or "safe mode" where you can reset it. It varies from tablet to tablet, however. For example, on my Haipad M701-R when I flip the on/off switch off and then on, short press the "end/sleep/power" button and immediately press and hold the "Menu" button through the boot process I go into "Safe Mode."
Also, some APAD tablets have a small, unmarked hole on the side of them that you can stick a paper clip into and press a soft-reset button. No idea if that clears an unlock pattern though.
4. If those options don't work, or if you have not set up a Google Account (either because you bypassed it or you have a tablet without official Google apps on it) another option is to use ADB (Android Debug Bridge) to unlock it. Go to Google and download the Android SDK (if you haven't already) and install it. If you're on Windows you'll also need the USB drivers.
1. Plug the tablet into the computer via USB and turn it on/boot it up.
2. Open a Terminal/Console and change directories to your Android SDK /tools/ folder.
3. Enter ADB commands. On Windows these will be "adb.exe" and on Mac/Linux "./adb" - I'll just use "adb" below for simplicity:
Code:> adb devices
This will let you know if ADB can "see" and "talk to" the tablet. If you don't get any devices reported back check the USB cable, drivers (on Windows), and that the tablet didn't shut down on you. I should warn you, however, if the tablet didn't have "USB Debugging" turned on, this will not work. Assuming it reported back finding a device proceed:
Code:> adb -d shell # sqlite3 data/data/com.android.providers.settings/databases/settings.db sqlite> update system set value=0 where name='lock_pattern_autolock'; sqlite> .exit # exit > adb reboot
If all went well the tablet should now boot WITHOUT the pattern lock enabled!
It will probably ask you for account info again like the first time it was booted. You can bypass that by pressing in all four corners in sequence upper left, upper right, lower right, lower left (if I recall correctly). Once into the tablet perform an actual factory data reset or it will pester you for setup info EVERY time you boot it. Go to Privacy>Factory Data Reset>Reset
5. Last resort is to reflash the tablet. Without knowing SPECIFICALLY which tablet model you have, though, there's no way anyone could tell you how to flash it or where to get compatible firmware. Assuming you DO know what you have and where to get a compatible rom for it, check elsewhere on the forums for instructions on how to flash your specific tablet with that firmware. Once it is flashed the "drive" is wiped and reset so you'll have to
go through the "first run" setup again, but at least it won't have a pattern lock on it.
Jan 16, 2012 | Archos 70 Internet Tablet
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
Amana ADB 1200AWW
Aug 29, 2008 | Amana 24 in. ADB1200AW Built-In Dishwasher
Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Aug 13, 2007 | Canon PIXMA iP1600 Printer
Amana 24 in. ADB1200AW Built-In Dishwasher Logo
118 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
