Question about HP iPAQ H1910 Pocket PC
HP iPAQ 1910 does not charge
I got a used ipaq 1910. bought a new battery and the docking station+charger (for 1910) because the old ones were dead. now the device turns on but does not charge the battery and activesync can't find it when connected to the P.C.
I'm not sure if I am doing something wrong or if the device has a malfunction.
  • 1bigcat Aug 23, 2008
    I have a new battery please tell me how do I change it does it go in the PC or someplace else Im lost
  • Anonymous Nov 24, 2008
    charge light does not ccharge
  • 3 Answers
It could be the mainboard on the ipaq is messed up. Bring it to a local tech maintenance shop
Posted on Jun 03, 2008
Internal battery charger
Yes you can buy them on e-bay here is the link for one
http://www.ebay.com.au/itm/Charger-For-HP-iPAQ-hx2100-hx2400-hx2490-hx2750-364401-001-367205-001-/360527673086?pt=AU_MobilePhoneAccessories&hash=item53f11fb6fe just charge up the battery externally and away you go I bought a second battery so I can have one on charge charging while I am using the one in the IPAQ so no down time
Dec 08, 2013 | HP iPAQ HX2490 Pocket PC
Have had a HP ipaq rx1950 for about 2 years and last month it has stopped charging the battery. I bought 3 batteries and each one does not charge. I put these batteries in another person's ipaq and...
its just 3 things.
1; battery
2: charge regulator on the device.
3: power pack
one is bad.
so its not battery, now its #2 or #3
seen the regulator is toasted
very common
why not buy as used spark same device, and mix part to get good
or ditch it and upgrade,
Mar 12, 2017 | HP iPAQ rx1950 Pocket PC
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I just bought a battery charger, plugged it in and its not charging
I suggest to you to buy a new battery for you HP iPAQ H4150 Pocket PC and see if that charger will charge it up. If the new battery does charge then the problem was with the old battery.
If it doesn't charge up on the new battery then, your problem lies with the battery charger. You should check that the voltage of the battery charger is compatible to charge the voltage of the battery.
Hope I have been of assistance to you,
Cheers :)
Apr 24, 2010 | HP iPAQ H4150 Pocket PC
IPAQ 1910 Backup Battery Is Dead, Doesn't Take A Charge
You need a new battery and yes you can replace it.Check with HP or a wireless store for the right battery type
Aug 29, 2009 | HP iPAQ H1910 Pocket PC
I have an HP Ipaq h1940 pocket PC. It won't charge!
Charge the dead battery with other good battery for a while first.
Jul 29, 2009 | HP iPAQ H1945 Pocket PC
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
Battery won't charge after being replaced
The charger might be bad. Or then the pdas connector is bad, or the motherboard is damaged.
to find out is your charger working you could use a tester to test it or another pda.
If you could get some power into the pda you could use the bootloader to test the device. Its been years since I had my 3850.
Il have to find instructions on how to get to the bootloader but test the other things first.
Drop a comment.
Mar 11, 2008 | HP iPAQ H3835 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H1910 Pocket PC Logo
293 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
