Question about Xerox Office Equipment & Supplies
Jams Everytime you go to print something a message comes up and says jam at tray 2. But there's no jam.
    President:
  • 2,072 Answers
First of all, the feed rolls may be very slick, try cleaning them several times with fantastic or 409. They are probably very smooth and just spinning on the paper.
The feed clutch or motor, depending on the model, may be bad and not driving the feed rolls.
The paper tray may not be lifting the paper stack to the rollers.
Posted on Jun 05, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Paper jam in tray 1?
Maybe the sensor is faulty or dirty. Sounds intermittent
May 15, 2015 | Lexmark T650n Laser Printer
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
Cartridge jams during printing
Uneconomical to repair. It's time to buy a new printer.
Dec 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam
Seems you have a dusty roller in the feed mechanism. try cleaning off the roller with some windex (or equivalent) on a towel.
Nov 18, 2008 | Brother MFC-9420CN All-In-One Laser...
Hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Oct 03, 2008 | Office Equipment & Supplies
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
