Question about Samsung BN59-00678A Remote Control
My bn59-00684a will not operate my tv the only thing it will do is switch it on.
  • 100 Answers
Its a bad remote send back to samsung or get a universal remote
Posted on Oct 16, 2010
Remote makes tv start to operate then flicks of to standby immediately
Hi Barrym,
You have not mentioned anything about the make and model of your TV. If you do so, it will help us to suggest you the solution. Your TV is going in the protection mode as soon as you switch it on. There can be several things responsible for this. A proper check can decide the actual cause. Please consult some local TV tech.
May 31, 2015 | Televison & Video
Ur5u-8780l not operating channels on Magnavox TV. Tried all codes and switched channel control to TV, still nothing.
If you are using a universal do not expect it to even if it programs to have all the functions you need or want or had with the original remote.
Universal remotes are far from UNIVERSAL.
The best argument for an original remote is even if it programs it will just not have all the features needed or wanted that the original had.
Hope this clears things up a little.
Apr 03, 2012 | Televison & Video
Tv#2 plays the exact same thing as tv#1. remote that goes with tv#2 not working cause remote of tv#1 working both tvs.
dbdandrld,
It sounds like the receiver may be in Single Mode which will make both TV's show the same picture. On the lower right hand side of the receiver will be a mode light. If it is under Single then press the mode button (may be inside a panel) and it should switch to Dual mode. This will allow both TV's to operate independently. Let me know if the problem persists!
Tommy Faust
DISH Network
Sep 24, 2011 | DISH Network ViP622 DVR DTV Receiver /...
The tv doesn't turn on. checked power and both dvd and cable box work.
Obviously you must make sure the power is plugged in.
You should also try to get up and manually operate the power
switch on the thing, to be sure some of the 'StUpId' things aren't the actual problems.
I could be the remote!
When all of this is for sure, call a tech. Its big and dangerous for you to get into the back of.
If you were in VB you could ask me.
PLEASE RATE THIS ANSWER
Aug 29, 2011 | Panasonic CT-32E13 32" TV
Remote will not move the channels but will switch the tv off
check if remote is made for same model of tv, try operating the tv from switches on front or side of the tv, if operating, replace the remote.
Aug 19, 2011 | Televison & Video
29" LG Flatron TV bought in 2007. On starting TV,
That kind of prolem is commonly caused by dried electrolytic capacitor on the low voltage power supply. Leaky capacitor affect the performance of the B+ once sense by the processor it will automatically shuts down the unit.
I've advice you to send it to qualified service center to isolate the problem because oscillator is also going to check for normal operation. This is quite technical and not DIY.
Thanks for using fixya.
Please rate my help.
Jan 17, 2011 | LG Televison & Video
Hdtv only the power button work.
What "inputs" are on the back of the TV,
so that you can connect the PlayStation and/or the DVD player?
Is there a "setup" button on the TV itself,
and "up/down" and "left-right" and "select" buttons,
that you can use to tell the TV to accept input from "tuner" or "cable" or "DVD" or "Composite" or "SVGA" sources?
Can you telephone the Dish Network support-desk, and get them to "program" your Dish Network remote-control with the specific settings for your specific brand/model of TV?
Apr 28, 2009 | Microsoft Windows XP Home Edition
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
Jan 31, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Sony KV-27FS100L -
This is due to switches malfuction due to corrosion in switch and dust accumulated in the switch. Since you rarely used switch now after failure of remote of remote control you tried to operate the switch. Another thing you said did"t get picture, maybe memory problem is there. This can be sorted out by the technician only.
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung BN59-00678A Remote Control Logo
631 people viewed this question
Henry  Thomas
Henry Thomas
