Question about Quinny Buzz Three Wheel Stroller
The front wheel seems to get jammed every now and then.. how can this be solved?
    Problem Solver:
  • 8 Answers
Try useing wd40 where the wheels meet the axle.
good luck
jim
Posted on Oct 16, 2010
How can I adj the steering on this tractor it seems the front wheels are out of line with each other?
Im guessing its an MTD. They come from the factory with severe toe out. Luckily the drag links have adjustable ball joints. Break loose the jam nuts and remove the ball joint from wheel spindle. Count the number of turns so you can put it back if need be. Don't ever do it. Do 3 or 4 turns at a time. Reassemble and assess. Once you have it where you want it retighten jam nuts
Sep 01, 2014 | Garden
Ive replaced the cv shaft but the noise is still their...any ideas?
Have you checked the front wheel bearings? I've seen similar problems on several front wheel drive cars. On my first experience, we also started by changing the CV joints only to find it did not solve the problem. We then though it was a transmission problem.... wrong again. Finally checked the front wheel bearings (Both sides) and found the passenger side was making the noise. Bearing replaced (not cheap by the way) but solved the problem.
May 04, 2012 | 2007 Ford Focus 2.0
Always in 4 wheel drive
Confrim this by lifting the front wheels off the ground, if that is the case the 4X4 Transfer case may be jammed or low on fluid. You may also have a defective actuator at the transfer case.
Feb 15, 2012 | 2003 Ford Ranger Regular Cab
Front left hub and wheel get extremely hot. no pulling
Please get the disc brakes checked, it may be jammed causing friction on disc causing the heat. For a try, you can take car on empty road and do some short sudden acceleration and hard braking. This way jammed disc brake may free up and solve your problem.
May 10, 2011 | 1993 Plymouth Grand Voyager
On my Elna SU ,The front white top selector is jammed
Have you turned the stitch width and stitch length selectors back to zero each before trying to change the stitch selector wheel? Really important to always do this.
Have you resolved this issue now?
Jul 23, 2010 | Elna 1010
The front wheel assembly is wobbly. Cant seem to find a new wheel anywhere. Thought that fixing it would be cheaper than getting a new trike but maybe not?? Thanks Jodie
you'll want to start by taking the front wheel off of the bike. there are two nuts on the axle on each side of the hub. (besides the ones you loosened to remove the wheel) the two inside nuts keep the bearings tightly in position inside the hub, and the two outer nuts are jamnuts that are tightened to the two inside nuts to keep them from turning once you've got the tension set. so loosen the jamnuts from the tension nuts, set the tension tight to where the wheel doesnt wobble but not so tight that the wheel doesnt spin freely. then tighten the jam nuts while holding the tension nuts in place with a wrench so that the tension nuts dont move when you're tightening the jam nuts. take your time and you'll be fine. I hope this helps and Good luck!
Feb 18, 2010 | Cycling
I have a 2005 fx4 supercrew when backing up my driver side front wheel doesnt seem to be turning. but in forward it seems to work well.
you have bad pads or you have something jammed into the rotor that causes the wheel to lock up when turning in reverse. you may have a problem with the front axle or the from differental get it checked right away to avoid expensive repairs.
Jan 11, 2010 | 2005 Ford F-150
Seems like front brake engaged
Is yr bike fitted with disc brakes to the front?
If yes thn you will have to overhaul the brake calipers, it seems the pistons have jammed in there probabely due to rust on it at the pitted areas.
Better still is to overhaul the brake mastercylinder too.
Good luck
May 25, 2009 | 2000 Suzuki GZ 250 Marauder
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Quinny Buzz Three Wheel Stroller Logo
69 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
