The fax machine power is on and powered up, but it will not recieve or deliver any faxes. I have tried to fax papers and they go through the process but I always get a error reply. Please help me to understand what my issue may be. Thanks in advance for your help, Arlena Kilgore
Arlena; First of all, check the phone line going to the fax machine. I would connect a phone to this line and see that this phone it is working and I can do an receive calls. Then, remove the phone and connect th fax machine againg.
Hope this helps.
Posted on Oct 16, 2010
Sf5100 says recieve error
take the power out and hold the red button in. put the power back
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Cannot recieve or send faxes. Machine can still copy though. says "change paper size"
Unplug the fax from power for a minute or two.Check the paper size under fax sett., clean rollers,...
Feb 16, 2010 | Canon FAX-L380 Plain Paper Laser
All of a sudden, faxes stop coming out and the window says something to the effect...''Place US Paper in Upper Tray''. If I turn the machine on and off, the display clears and faxes that are in memory...
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
May 01, 2009 | Xerox FaxCentre F116 Plain Paper Laser
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
Can't recieve a fax.
Unplug power cord. Plug back in. Call your fax machine from cell phone and listen for fax tones.
Sep 17, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
jasbo
jasbo
