Question about Brother MFC 6490CW InkJet Printer
Just put new cyan cartridge in and now it won't print blues. Was fine before this cartridge change.
Please try with the cleaning printing injectors routine. Sometime it is necessary to repeat the cleaning process two or three times.
Hope it helps.
Emilio
Posted on Oct 16, 2010
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
The colors do not print correctly.everything is blue/green/yellow. the ink cartridges are new. black prints fine. the troubleshooting optin only lets me select to remove lines, it wont let me adjust the...
The magenta cartridge isn't working correctly. This is why you're only getting the other colors (blue is cyan, green is cyan and yellow, and then yellow).
Try removing and reseating the magenta cartridge. If that doesn't work, use a new magenta cartridge (the cartridge itself may have been defective).
I wasn't able to view a manual for this machine, as it's been discontinued and Lexmark no longer offers the PDF on it. If you have a "clean print heads" option, use it. It may require more than one try. If you don't have that option, then all possibilities have been covered.
Hope that's helpful.
Jan 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
Whenever I print color, entire page comes out blue. I have replaced the cyan cartridge (twice) and the Laser Transfer Kit. Sometimes there are thick blue streaks in addition to the overall blue color. What...
Run the "disable cartridge check"
It will be in the Diagnostics.
Once you start the test, you can remove all the cartridges. Put the cyan in the black cartridge slot.
print a config page. If it is all blue, you have another bad cartridge. If it prints correctly(minus the other colors)...continue
Now put the magenta in the cyan cartridge slot. Print the config page again. If you have red all over the page, you have a problem with the slot itself.
Press the STOP button and then select EXIT diagnostics. Put the cartridges back where they all go and run CALIBRATION more than once.
Select/menus/down arrow/configure devce/select configure device
Down arrow/print quality/seect print quality
Down arrow/ calibrate now. Select it and wait.
Oct 25, 2010 | HP Color Laserjet 3550 Printer
I just replaced the cyan cartridge and I get 4 blue lines that print where they should not be. If I print a blue picture - those line tend to be a lighter blue. I have taken the cartridge out and replaced...
Obviously you need to return the Cyan cartridge to where you got it. It is bad. Is it OEM Samsung or is it remanufactured. If it is remanufactured then it will usually say "for use in" or "remanufactured" somewhere on the box.
Either way it sounds like you need a replacement cartridge under warranty.
Sep 14, 2010 | Samsung CLP-600N Laser Printer
When my screen shows that some items are to print in blue they actually print in red.
Sounds like you are missing cyan. Change the cyan cartridge. If you have not used color on the printer recently, the head may be blocked.
If the head is blocked, try putting the color cartridge on a piece of * slightly * damp piece of paper towel. This should draw color out of the head onto the paper. Once you get blue (cyan), you should try printing again.
Jun 12, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
Installed a new cyan cartridge, but the blues show up as pink..
I can assure you that you got a bad colour ink cartridge. However, you may try this: get a small ply of tissue paper and place over the printing head, with your mouth and some good measure of pressure **** it. Repeat a couple of times and all the three colours: cyan, magenta, and blue will show up; otherwise replace immediately. Good luck
Apr 30, 2009 | Xerox Phaser 6180N Laser Printer
Added new cyan ink cartridge and won't print the blue colors
Nope, It's just going to take lots of pages before it comes back...maybe the whole cartridge
Mar 03, 2009 | Brother MFC 420CN All-In-One InkJet...
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Brother MFC 6490CW InkJet Printer Logo
101 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
