Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Brushes won't spin - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
  • 13,433 Answers
Hello, and thanks for using FixYa.
I'm guessing that the brushes have become jammed, there is most likely hair, or something similar that has build up inside and its preventing the brushes from spinning. Make sure you turn off / unplug the vacuum before you start cleaning it.
  • Clean the brushes with great care to get them spinning again, make sure they are clean like new.
  • if there is a separate power cable that goes from the top to the bottom brushes, make sure its properly connected
If after doing the above the machine has not improved, then most likely either the brushes are not getting power, or the motors have broken - this can happen if it is not cleaned and the brushes are dirty, the motors are under constant heavy stress to rotate the brushes and can eventually burn out.
I would not recommend going further than this at attempting to repair this yourself. If there is a electrician in the house, he or she could use a multimeter to check if power is going to the motors in the bottom. If there is no power down there, the issue might be no connection or broken on off switch.
If the motors get power but don't spin then most likely they are burned out or something is preventing them from rotating.
That is about it. the motors might need to be replaced to new ones.
Thanks,
Ekse
Posted on Oct 16, 2010
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Troubleshooting
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
Jun 26, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
Brushes don't spin
I'm sorry to hear you're having difficulty with the motorised brush head on your DC31 Animal. If the head won't seem to work correctly after you've checked for any obstructions, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, as one of our advisors may be able to resolve the issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 11, 2012 | Dyson DC31 Animal Bagless Handheld...
Dyson dc14 brush won't spin
Liz thank you so much for the quick fix. Moving the carpet/floor knob a few times reset the belt. My method of slamming it against the dresser did not produce the desired results.
Feb 10, 2012 | Vacuums
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won"t spin, Model F7452-900
SAME PROBLEM Hoover F7452 900 brushes won't spin; cleaned and move freely, under filter slid out and cleaned, still froze up....had it a little more than a year so probably no warranty.....assuming turbine related and will take it to dealer......how common is this problem with this model???
Jun 15, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
580 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
