Question about Samsung L100 Digital Camera
Will not turn on and the lens stays out Even when power light come on. The only way to power off is to remove the battery
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 16, 2010
Wont turn off-on
Taking out the battery, when a camera acts strange, is a good thing ONLY. be sure the camera is not busy saving pictures, because you could damage all pictures on the memory card.
I'm not sure the lens was out, when it was connected to the computer. Let us assume it was. Normally, the battery should be charged when the camera is connected to a USB connector on the PC. But not all USB connectors are perfect wired. And if you use a USB hub you can be sure the battery was not loaded. So as soon as the camera came from the PC it needed full power and could not get it.
Now you removed the battery, but before placing it back in the camera, please charge it on an external charger. When you place the charged battery, and the yellow light starts flashing again and won't stop quick, you could try to reconnect the camera to the computer and see what that brings. I would have switched off the camera, before I disconnected it from my PC.
Than the sand issue. If just a grain of sand is in the lens bellow, it could serious obstruct the lens from going back. If you can see the grain of sand, you could try to get it out. Very thin needle (or two?)
But if you can't see something, don't move the lens at all.
You could damage the gears in the focus and zoom mechanism.
I wish you luck with the camera.
Nov 11, 2013 | Samsung Digimax EX1/TL500 Digital Camera
When I turn the power on the lens extends out of the camera and the power on light immediately goes off. The lens stays extended. no photo can be taken. This is a SonyDSC-P73 camera.
The only time that happens with mine is when I am low/out of battery power. I usually have to replace the batteries (even if the lens is still out) and then it works fine. Find it happens more often with rechargeable batteries because they still have a bit of power left, where regular batteries have nothing left after they 'die'.
Mar 05, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
The lens does not extend on my easy share dx7440 and the power won't stay on.
This is apparently a common problem with this model Kodak. The most common do it yourself fix for this issue it to manually hold the lens out when turning this product on. Do not let the lens retract even an inch and the camera should stay on and continue to work properly. If this does not work repeat the process a couple of times in a row to see if you are able to achieve results.
Oct 07, 2010 | Kodak EasyShare DX7440 Digital Camera
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
Lens stays out- "Bip Bip" when i turn it on but no other reaction
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 21, 2010 | Samsung HZ10W / WB500 Digital Camera
Will not power up
There are several reason why digital camera doesn't stay ON even when the batteries are fully charge or use brand new batteries. You can try to do the following steps to make sure that there is something wrong on the camera and not just batteries.
- Remove the batteries from the camera and the memory card
- Make sure that your using a brand new batteries
- Clean the battery contacts with a clean dry cloth
- verify that the batteries are inserted correctly
- Set the camera in Auto then turn it on
[Listen if there is a grinding sound on the lens part of the camera.]
Most Digital Camera turn itself Off when the lens won't zoom. So, if your camera start up and lens moves before it turns off and you can switch it on a different mode and it works. You need to contact your camera manufacturer and have the camera sent for repair. It might be wiring issue on the lens part of the digital camera
Nov 17, 2009 | Cameras
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Camera turns off after lens comes out in shooting mode.
I'd recommend that you stop banging or fiddling with the lens as it does not sound like a lens error (if it were so, you'd still get an error even in review mode). Instead it sounds like the brand of batteries that you're using may not be providing sufficient power.
Alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Most retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
May 15, 2008 | Canon PowerShot A530 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Samsung L100 Digital Camera Logo
49 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
