Question about Samsung Refrigerators
My six month old Samsung fridge freezer stops freezing. But if I switch it off at the wall and wait a few minutes it works again. But then stops freezing again. So I switch it off at the wall for a few minutes, and it starts freezing again. I've bought a timer which turns the fridge freezer off at the wall every 3 hours for a few minutes, and it is freezing as it should, but it's obviously not ideal. Have called in the Samsung repairers, but no word from them as yet as to a date to come by.
    New Friend:
  • 4 Answers
Its a Samsung that is the whole problem.
Posted on Aug 26, 2014
  • 828 Answers
There is a possibility that you have a problem relating to the internal refrigeration system. It may contain moisture contamination which freezes in the refrigerant feeding device. Shutting it off allows the moisture to melt and restart the circulation of refrigerant. This problem can only be solved by a certified refrigeration technician.
Making sure the condenser is free of dust and dirt will improve the ability of the system filter/dryer to absorb and hold moisture.
Posted on Jun 03, 2008
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Ice develops at back of fridge
hi chris
dave here hope i can help
I would test the defrost timer, defrost heater or defrost limit switch
TESTING AND REPLACING THE DEFROST TIMER
This timer activates the heater that melts frost in the evaporator for 10 to 20 minutes every 10 to 12 hours. In the process, it turns the compressor off and on. If it fails, the compressor may not run. Or the heater may not go on, eventually causing a hidden ice buildup that blocks the cold-air flow and disables the evaporator fan. An access hole lets you test the timer. If the timer isn't in the control panel, look behind the front grille or behind the rear access panel. If the compressor fails to run turn the timer until it clicks. If compressor goes on, timer is faulty. If unit isn't defrosting automatically and turning timer stops compressor or fan, timer is faulty.
Before replacing timer, spray it with electrical contact cleaner through access hole and turn it a few times. Stop just before a click and wait to see if timer advances on its own.
To replace timer, unplug the refrigerator and open control panel. Remove screws holding timer to panel and pull of leads. If wires aren't in a plug, move then one at a time to new timer.
EVAPORATOR AND DEFROST HEATER
In a frost-free unit, the evaporator coils, their fan, and the deforst heater are located behind the freezer's back wall or under its floor. The fan, which circulates cold air between the coils and the two food compartments, is controlled by the door switch, the thermostat, or both. To check the fan, open both doors, wait for the compressor to go on, and hold in the door switch. If you can't hear the fan running, test the fan(below).
The defrost heater, which melts frost on the coils, is cycled on by the defrost timer(above). If the frost melts before the end of the defrost cycle, the defrost limit switch turns the heater off. The heater may be a metal rod, a wire wrapped in foil, or a coil inside a glass tube. All are tested the same way. Test terminals for the heater are often located in the control panel or under a doorjamb; check the wiring diagram. Or test the heater leads inside the evaporator compartment.
TESTING THE EVAPORATOR FAN
To remove the evaporator fan, unplug unit; open back panel(or floor) of freezer. Then unscrew housing holding fan, and take off leads going to fan motor. With VOM(Volt-Ohm Meter) on RX1, probe motor terminals(except green ground wire terminal). Look for moderate resistance(50 to 200 ohms). Replace fan if much lower or infinity.
TESTING THE DEFROST HEATER
Open control panel. With VOM on RX1, probe test terminals. Look for 15-to 100-ohm reading. If infinity, turn defrost timer(as above); retest.
TESTING DEFROST LIMIT SWITCH
Trace and disconnect leads. With VOM on RX1, probe leads. Look for infinity reading when switch is warm, zero after 20 minutes in working freezer.
Hope this sources your problem
Thank you for using Fixya.com
Jul 20, 2008 | AEG Santo U 86000i Compact Refrigerator
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
I have a side by side fridge model is GSS201BTA
There are 2 ways I would handle this so you decide.
First open the freezer door and push in the door switch on the left hand wall. Wait a few seconds and see if the fan starts blowing. If not wait abbout 30 minutes and try again and if it still wont blow you will need to replace the fan motor. If the fan does start blowing either time look at the lower back wall and see if it is coated in a layer of frost. If so you have a defrost issue and will probably need a heating element or a new control board.
Your other option, call GE and tell them they sold you a lemon. Explain to them that you had service shortly after buying the unit for the same reason your calling them now, and you should have had them replace the unit while it was still in warranty with the first problem. You paid good money for the refrigerator and its not right that they treat this any other way then to cover any repair costs for you. And usually they will considering the first problem you had 2 weeks after purchasing it. Hope this helps.
Jan 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung fridge RS2630, icing up on freezer and fridge not cooling
Could be the defrost element. If it does not work and melt the ice off of the evaporator, icing will continue and serve as an insulator. Freezer and refrigerator temps will suffer.
If you unplug the unit and let it defrost for a day and plug back in it will work fine till it freezes up again.
Jun 25, 2017 | Samsung RS2630WW Side by Side Refrigerator
My refridge and freezer would stop working
there is a saftey overload switch on the compressor when the compressor is over heating it cuts out. when the fridge is turned off it resets the switch. So now the compressor has burned out totally. you more and likely need a new compressor
Feb 03, 2009 | Frigidaire FRT21P5A Top Freezer...
Fridge freezing up on back wall of fridge not defrosting
is freezer fan working?remove freezer back wall put frig. in defrost,watch freezer to see if the heater is melting the ice,if not wait 20 minutes till freezer out out of defrost and fan comes on,if it does you have a bad heater and bimetal switch (the little silver round thing clipped on coils,let me know-mike
Sep 22, 2008 | Refrigerators
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
147 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
